I do sometimes wonder! Someone will give a perfectly good answer and then someone will come along and post exactly the same, or some absolute bollox.
I do love the Internet!
[awaits posts such as "Dave" or "flange"]
I quite like chorizo on pizzas.
If fish had feet, do you think theyd prefer clogs or cowboy boots?
[quote=wrightyson ]I do sometimes wonder! Someone will give a perfectly good answer and then someone will come along and post exactly the same, or some absolute bollox.It's useful to get a few responses to the same question; (a) there can be different answers/approaches, (b) getting more than one similar answer is (often) confirmation that the answer is correct.
Examples or it never happened
I agree,but you wouldn't want to be trapped in a lift with him.
No because 29ers are wrong
It's useful to get a few responses to the same question; (a) getting more than one similar answer is (often) confirmation that the answer is correct., (b) there can be different answers/approaches
It's probably been shot down by an American drone.
What would Hora do?
Totally agree with the getting a few answers the same, but sometimes the odd person will post as though they've just discovered the theory of relativity versus the rolling ratio of a 29ner, even tho Dave the baker and Geoff who rides a hybrid single speed 6" full suss had come up with it two posts before. Sometimes an acknowledgment of someone else's knowledge/wit/well readness/general comen sense with a +1 is quite a nice approach.
don't you just hate it when people keep repeating stuff over and over again.
Comen!
sometimees folk quote and +1 so some must
I dont like to quote so dont do this 8)
HTH
FLOUNDER! Run away....
To get it just right, loosen the B-screw until the top pulley begins to rub, then tighten the screw to get some clearance.Job done.
HTH
Danny B
I always read the entire thread so that hopefully I'm less likely to appear to be a fool.
+1 all the above.
did you actually try searching? I'm sure we cover this once a week.
+1000 to something somebody said ^ there somewhere @random
Flipflops
What do you mean you told your kid the tooth fairy doesn't exist!?! You heartless lady garden 👿
Definitely flange, but I suppose if I was marooned on a desert island for years with no other choice but Dave, then who knows?
/awaits crikey to come along and tell the OP to MTFU/
Chicken, failing that the Egg.
You can clean sudocreme off with Picolax
Utter toss, Egg, failing that the Chicken.
7 if I remember correctly, but could be blue.
Errrr...... What was the question?
yes but not everyone only rides at trail centres
ALWAYS read the posts, that way you know where all the best cheeky footpaths go to...........
I repeat myself when I'm under stress, I repeat myself when I'm under stress, I repeat myself when I'm under stress,
I repeat myself when I'm under stress...
I like it when someone will give a perfectly good answer and then someone will come along and post exactly the same, or some absolute bollox.
You would need some good insulation to post absolute zero bollocks otherwise they would warm up while in transit.
Consider buying a pair of 180mm cranks apparently, (or 165 or 170, **** knows why?!)
Which is best ?
