Does a real man nee...
[Closed] Does a real man need a sledge hammer?
35 Users
Storm Hector has made one of my trees lean over at about 20 degrees, grrr!
I have bought some tree stakes and tree ties and I intend to make the tree upright over the weekend and then secure it to the stakes with the ties.
I have a lump hammer that I inherited from my grandfather a good few years ago and that would probably be enough to knock the stakes in.
However, I have a hankering for a sledge hammer, but after knocking the stakes in I don't know what other jobs I could do with it.
Should I buy one or will my lump hammer be up to the job?  Hmmm.
Posted : 15/06/2018 9:48 am
I have sledge hammer and a splitting maul with sledge on reverse of head.
Tools = n+1.
Twice the man.
Posted : 15/06/2018 9:51 am
Yes.
Posted : 15/06/2018 9:52 am
 km79
No. Just thump them in with your fists.
Posted : 15/06/2018 9:54 am
 Yak
Just get a maul. Sledge side for securing the stakes. Maul side for splitting it all up once it finally falls over.
Posted : 15/06/2018 9:55 am
Does the tin man have a sheet metal cock?
Posted : 15/06/2018 9:58 am
yes, yes you do, just dont by silverline as i once saw a very angry man returning  one which the head had snapped off and hit him in the face... his response to the offer of a replacement was to say the least a bit controversial and i doubt it would  have fit....
Posted : 15/06/2018 9:59 am
No, a real man would drive them in with a devastating stare.
my 6 yr old son appeared round the corner in a DIY store last week wielding a 3lb short handle sledge hammer above his head asking if he could buy one with his pocket money.
so yes.
#prouddad
Posted : 15/06/2018 10:06 am
You have to ask?
Sledge Hammer and an Axe are the only tools you need.
Posted : 15/06/2018 10:12 am
A real man would pull the inadequate tree out of the ground and burn it.
Mercy is for the weak
Posted : 15/06/2018 10:13 am
I have never heard of a "maul", so I will have to go and have a look for one.
I don't have an Axe funkmasterp, so I will have to look for one of those as well, ha ha!
Posted : 15/06/2018 10:18 am
I have never heard of a “maul”
You sir have just lost 100 man points.
Posted : 15/06/2018 10:20 am
Stick with your lump hammer, anyone even asking the question probably won't be able to aim straight enough to hit the stake anyway 😉
Posted : 15/06/2018 10:26 am
And another -100 for no axe. Today is not turning into a good day for you Sonny-Jim!
Posted : 15/06/2018 10:34 am
What you need is a fence post driver thingy 😉
Posted : 15/06/2018 10:41 am
I have never heard of a “maul”, so I will have to go and have a look for one.
Dear Lord, we pray for the weak among us, may they find The Way.
Posted : 15/06/2018 10:44 am
That’s just a toy.
Posted : 15/06/2018 10:46 am
I spent my trailbuilding years mostly building on the side of very steep slopes which required extensive shoring of the outside edge of the trail with fallen logs, to stop it all disappearing down the slope!
A sledgehammer was a gamechanger, instead of having to hew perfect little stakes to support the logs and tap them in with the backside of the hatchet, I could just mash any vaguely cylindrical lump of wood into the ground with the sledgehammer, and call it a stake 😀
Posted : 15/06/2018 10:56 am
Maul....
Axe....
Posted : 15/06/2018 11:02 am
 CHB
Mattocks are good too! very satisfying kit to use. However my fave "big job" bit of kit is my persuading chisel. I don't know what the proper name is for it, I bought it from screwfix to break up some concrete that had been holding in some fence posts. It basically is a 6 foot long solid inch diameter steel bar hammered into a chisel shape at one and and flattened at the other (presumably so you could hit it with something). It weighs about 15kg and will literally mash through anything, concrete, tree roots the lot. For delicate jobs I have a Makita SDS with chisel. 🙂
Posted : 15/06/2018 11:03 am
persuading chisel
I think that is actually intended for digging post holes and a brilliant job they do too in ground you can barely get a spade in.  Flints and assorted buried rubbish is no match, I suspect it would remove toes with ease if anyone strays too close
Posted : 15/06/2018 11:08 am
Sledgehammer:
Sledge Hammer:
Posted : 15/06/2018 11:23 am
 Pyro
Posted : 15/06/2018 11:31 am
 Nico
+1 for mattock.
Posted : 15/06/2018 11:41 am
I have a grubbing mattock and one of those persuading chisel, so can I get some of the man points back that I lost for not knowing what a maul is please?
Posted : 15/06/2018 11:45 am
A real man never begs for man points.
He just takes them.
Posted : 15/06/2018 11:47 am
Hammer of any shape and size = Yorkshire screwdriver.
Posted : 15/06/2018 11:52 am
Maul
Posted : 15/06/2018 12:11 pm
Pah, sledgehammers are for girls. My post knocker weighs 300 kgs and sits on the end of my digger 🙂
Great for gate posts and strainers but you need to go easy on stakes as 1 hit can sometimes be too much and you have to lift it back out again!
Regarding a proper sledgehammer, a real man can hold one by the end of the shaft at arms length, then lower the head slowly down til it touches his nose, then raise it back to vertical. All without bending his elbow. Try it 🙂
Posted : 15/06/2018 12:28 pm
I think the correct nomenclature is a Post Bonker.
mate of mine knocked himself out with one of them. lifted it up to drive a post, lost control of it and dropped it on the back of his head. sparked clean out.
Posted : 15/06/2018 12:33 pm
Welshfarmer, the 7 pounder on to the nose was one of the challenges between apprentices when I was a lad. I could do it then, but I'm not so sure now, 40 years later.
OP, if you've a hankering and can afford it, you may as well get one now, it'll certainly knock the stakes in more easily.
Posted : 15/06/2018 12:44 pm
Posted : 15/06/2018 12:52 pm
Posted : 15/06/2018 2:13 pm
^^That's the OP when he asked what a strainer was 🙂
Posted : 15/06/2018 2:19 pm
No.  A real man already has a sledgehammer.
Posted : 15/06/2018 4:40 pm
Wrecking bar.
A most satisfying tool. Fnaar.
Posted : 15/06/2018 4:57 pm
I’ve got two sledgehammers! Well, I’ve actually got one out in the garden that could do with a new handle, the other is just a head that I *ahem* ‘aquired’ some time back that was pretty rusty so I went at it with a wire brush on my angle-grinder, which revealed traces of red paint and ‘GPO’ stamped into it. Makes a good anvil for hammering small things on. I’ll get new handles for both of them some time soon.
Posted : 15/06/2018 6:23 pm
However, I have a hankering for a sledge hammer, but after knocking the stakes in I don’t know what other jobs I could do with it.
You could play croquet
(Although that also requires some balls.)
Posted : 16/06/2018 12:04 am
Maccruiskeen wins the internet!
Posted : 16/06/2018 8:32 am
I’m about to commission a bespoke piece of Harris tweed cloth to be made into cushions. I’m more into that than a new wrecking bar or cold chisel.
a “real man” isn’t still bound to last centuries notions of what being a man is, it’s not giving a toss what others think and not being weighed down by thinking ‘I must get myself a bigger hammer’ for acceptance by your peers.
Posted : 16/06/2018 10:03 am
Using the correct tool for the job is one of life's great pleasures!
Posted : 16/06/2018 10:15 am
But successfully using completely the wrong tool for the job is far more satisfying. And manly.
Posted : 16/06/2018 11:11 am
Using a sledgehammer to crack nuts, for example...
Posted : 16/06/2018 11:57 am
OP , a good fencing maul is the correct tool for the job .
https://www.zoro.co.uk/shop/hand-tools/mauls-and-punners/fencing-maul-wooden-5-40kg-12lb/p/ZT1010379X
Posted : 16/06/2018 12:15 pm
 Leku
You also need a Mutt.
<h1 class="col-md-14 col-lg-14"></h1>
Posted : 16/06/2018 2:05 pm
