DIYists - Rawl bolt...
[Closed] DIYists - Rawl bolt/ Shield anchor removal. Some better than others?
10 Users
I'm planning on putting a TRX exercise anchor point (those straps you use for body weight exercise) up high on a wall. Indoors in a living room/snug/ man cave on a sturdy brick wall. But I don't own the house and will need to make good when I leave.
Are all shield anchors born equal in terms of extraction at end of life? Any top tips to make it easier - would greasing the internals help for instance? Last time I did similar for a plasma TV I ended up grinding them back with an angle grinder and re plastering over the stumps which was a right faff.
I appreciate that considering the repercussions in a few years time of my actions now completely diminishes my status as a self respecting man.
Thanks.
Posted : 23/01/2019 10:44 am
Is it a plastered brick wall? If so just sink some chemical resin fixings in, then you can just chop the fronts off, fill and paint.
Posted : 23/01/2019 11:13 am
Check out rigifix fixings.
Posted : 23/01/2019 11:15 am
Thanks both. I've looked at rigifix and whist they are intended for cavity wall I can't see why they would not work on a plastered masonry wall too. So I ordered a pair. I 'think' they will take the punishment of a 15 1/2 stone bloke hanging off a pair of them. either that or I'll have an interestingly new shaped nose.
Posted : 23/01/2019 8:43 pm
Are you sure that will work?
Do you not need some soace behind the angle of dangle to achieve some of the excercises?
Posted : 23/01/2019 9:22 pm
But I don’t own the house and will need to make good when I leave.
I'd be a bit pissed if my tenant drilled into my walls. Making good or not.
Posted : 23/01/2019 10:42 pm
I’d be a bit pissed if my tenant drilled into my walls. Making good or not.
I'm not really a tenant in the normal sense - house/flat comes with my job. They are pretty mellow about changes and alterations but I know the facilities guys charged with refreshing the accommodation between role holders moving in and out and would not want to give them extra work to do.
Posted : 23/01/2019 10:48 pm
If its a good solid wall there are screw in masonry bolts that cut a thread into the masonry as an alternative to an expanding rawl-type fixing. Means you can just unscrew them again later and nothing gets left in the hole.
Posted : 23/01/2019 10:51 pm
soace=space?
I would rather attach to the ceiling to be honest but they are daft high and a dangling TRX in the middle of the room would probably not pass muster with mrs C and a normal step ladder would not be long enough to fit and refit the strap between use. 8-9ft high up a wall is the best compromise I can make.
Interesting thanks - the chemical resin fixing above seems to get you somewhere similar too - possibly.
Posted : 23/01/2019 10:53 pm
Why would the landlord care provided the wall is fixed when he moves out.
Not many places fall down when someone drills a couple of holes in the wall. Wouldn't expect sympathy if you hit a pipe though...
Posted : 23/01/2019 10:55 pm
the chemical resin fixing above seems to get you somewhere similar too – possibly.
except it won't come out again... and that was sort of the brief 🙂
Posted : 23/01/2019 10:58 pm
except it won’t come out again… and that was sort of the brief 🙂
I found mixed references to that searching. Some suggesting that if your double nutted the thread against each other and then applied a bit of heat to the metal it is possible to screw it out. Others, not so much. That's why I didn't go that route however.
Posted : 23/01/2019 11:03 pm
Hey .... do you know some of those TRX systems come with a door jam ?
Might be an idea to give it a try before going to town with the SDS
Good luck
Posted : 24/01/2019 7:29 am
Ikve used the rigifix fittings a couple of times in block walls to hang a gun cabinet and they are solid. The FO could happily hang off it.
Posted : 24/01/2019 7:50 am
Hey …. do you know some of those TRX systems come with a door jam ?
Yes, got one of those. IMO they are a bit low as an anchor point but more pertinent in this situation is the door is not really in a position in relation to the room that works. But yes, a lot less faff!
Posted : 24/01/2019 8:09 am
Drill hole, resin in anchor sleeve a few mm below finished wall surface. Use big penny washer behind fixing to spread load. When moving out remove fixing and fill hole, flat back and paint.
Posted : 24/01/2019 8:46 am
When using any wall fixing it's essential to know in what direction the force is going to act.
If it's straight down, like hanging a picture, then just a nail will do. On the other hand if it's a top-hung wall cupboard then a large part of the load will be pulling away from the wall and will try to pull the fixing out.
In a solid wall I tend to use Fischer Duopower Nylon plugs, size dependent on the nature of the load.
Posted : 24/01/2019 10:54 am
Bolt all the way through....
Just remember to block one end begore you pour in a litre of filler in the other.
Posted : 24/01/2019 12:40 pm
