DIY world - texture...
[Closed] DIY world - textured ceiling
9 Users
Hi folks,
The "artex" in the kitchen has to go. Polycell do a product called SmoothOver. It sounds reasonably straightforward. Has anyone used it. I've heard textured ceilings can be a total PITA so I'm willing to try something that will make it easier
Posted : 13/01/2014 8:22 pm
Scrape off big lumps.
Pva
Overskim
Posted : 13/01/2014 8:23 pm
Get new plasterboard up and skimmed - we tried one product like that and it didn' work; another plasterer reckoned he could skim over another ceiling - again, did not work (that at least stayed on, you could just see the marks still when painted).
Re-board it yourself and pay someone to skim it.
Posted : 13/01/2014 8:26 pm
Didn't work for me. I ended up putting a second layer of plasterbaord and having it plastered.
Good luck.
Thanks folks sounds like it might be a bigger job than I thought
Posted : 13/01/2014 9:00 pm
Any plasterer should be able to skim over it easily. I do it all the time in new houses, for some reason the always have artex ceilings. If you wet it down, like you were stripping paper, it scrapes off super easy, right back to the board
Posted : 13/01/2014 9:13 pm
You scrap all the big bits of then a layer of bonding then you skim it
Posted : 13/01/2014 9:24 pm
Artex can have asbestos in it so maybe best to leave it where it is unless you can get a bit tested to check (only costs £10-£20 for a test direct with a UKAS lab).
We had out bedroom ceiling skimmed over. I primed it with new good quality PVA prior to plasterer skimming it. The result was quite good (not as perfect as new boards but still OK) and has stayed in place for the last year with no cracks etc. Plasterer cost less than 2 tubs of that Polycell junk and result far far better.
We had a fairly subtle random pattern to cover up - if you have some big regular geometric artex swirly horror then it might still show through in some light conditions.
Posted : 13/01/2014 9:30 pm
+1 on asbestos. Worth a look on the HSE website for up-to-date guidance.
Posted : 13/01/2014 9:39 pm
Remember if you do reboard the ceiling, to switch off the power and remove the fuse before you take off the lamp rose, had a job recladding a ceiling,home owner had disconnected rose left bare cables sticking therough ceiling, me in attic puilled cable back through ceiling, loud bang, darkness and me thrown accross loft, not a nice experience.
Posted : 13/01/2014 9:45 pm
