DIY gurus: Garage d...
[Closed] DIY gurus: Garage door not closing as tiles too high
6 Users
So I want to chamfer the edges of a tile or two, hopefully negating the need to lift the tiles up or break them.
My problem is a garage door that wont shut properly, I Have a tile cutter circular saw type thing, can you use these things free-style?
The interior of the garage has a tiled floor which is slightly too high, just in one spot that I can tell, preventing the door from closing and locking properly.
Thanks
https://flic.kr/p/2jLsvyg
Posted : 26/09/2020 5:02 pm
There's probably enough adjustment in the door itself or its mounts to fix this.
I can only imagine going freestyle with a tile saw ending in tears or A&E, or both.
Posted : 26/09/2020 5:15 pm
I'd start with the door. If there isn't enough adjustment then a diamond disk in the angle grinder.
Posted : 26/09/2020 5:17 pm
I cant see how to adjust it, its a basic mechanical garage door that locks on both sides
Posted : 26/09/2020 5:18 pm
Cut the tiles away to the shut line, also serves as a water run off.
Posted : 26/09/2020 5:22 pm
All the fittings look riveted
https://flic.kr/p/2jLtHuQ
Universal adjustment tool.
Posted : 26/09/2020 5:29 pm
Almost there... Just needs a bit more
https://flic.kr/p/2jLpWLJ
Posted : 26/09/2020 6:04 pm
Just adjust the door with a hammer.
Posted : 26/09/2020 7:44 pm
