Would you suffer any I'll effects from getting in a bath of what one could only assume is really diluted bleach.
For example if someone had cleaned the bathroom but left a few inches in the bath before running it?
Skin complaints most likely, even totally watered down multi surface shit will dry you out.
Empty it, rinse and repeat (minus bleach)
Do you really need to ask...!?
It feels refreshingly clean..... 😳
Your downstairs bits would know about it before the rest of your body 😯
have another bath (without bleach and soap) and soak
If it's very diluted I can't see why it would be a problem - most people drink diluted chlorine from their tap water without any ill effects.
EDIT : I'm assuming that "a few inches" is something of an exaggeration as it would take many bottles of bleach for it to be several inches deep in a bath.
I have known it recommended for certain skin infections.. Can only assume at the lowest of levels though rather than pube bleaching
Just shower it off. Like after swimming.
Once you're dry there won't be any bleach on you.
Looking at the PH table on the attached you either need to be very sick on yourself or go out to the car and pour battery acid over yourself
http://www.bbc.co.uk/schools/gcsebitesize/science/add_gateway_pre_2011/chemical/acidsrev1.shtml
Try a little bit in a beaker first.
Looks like he's just dipped it in the beaker.
Looks like he's just sipped out of it.
Ah yes, the old dip'n sip.
