Diesel engine quest...
[Closed] Diesel engine question
24 Users
Mrs Nomad has a 2003 Ford Galaxy TDi. I'm understand it has a VW PD Diesel engine in it (130bhp)
It's a fantastic load Luger and starts first time with little effort.
But
When the engine is cold, although it starts on the turn of the key, for approx 5 seconds it sounds rough (think brick in a washing machine noise) and this is accompanied by white smoke from the exhaust.
After 5 seconds, it runs sweet and the smoke has gone. No power issues.
Any idea what would cause this, is it something to worry about.
70k miles and FSH
N
Posted : 19/03/2014 7:46 am
If it's a VW unit and soundls clattery on start-up I'd suspect worn valve guides/stem seals - pulling oil through into the cylinders until it warms up.
Either that or a leaking head gasket, but in that case I'd expect the white smoke thing to get worse as it warms up, not better.
Is it using oil and/or water?
Posted : 19/03/2014 7:55 am
Glow plugs?
Posted : 19/03/2014 7:57 am
Oil and water are both fine.
I had thought it may be glow plugs but I've been told that they are rarely used unless temp is really low.
Would worn guides be an issue on a relatively low mileage vehicle?
Posted : 19/03/2014 7:59 am
You need the fault codes reading first. The Galaxy is a VW really, so you need to find a garage with a suitable VAG group code reader. VCDS is the default code reader for VAG group cars - or Autologic for specialists.
What is your location?
Hth
Marko
Posted : 19/03/2014 8:03 am
White smoke is unburnt diesel.
Blue/grey smoke is oil.
Grey smoke that then disappears is steam.
It sounds to me like you have a cylinder or 2 that isn't chiming in straight away on start up causing unburnt fuel to go down the exhaust. Have you checked the glow plugs? They are the most common reason for the symptoms you describe.
Posted : 19/03/2014 8:10 am
My old 1.8 TDI Escort used to do this until a blip of throttle. Glow plugs fixed it.
Posted : 19/03/2014 8:13 am
It has been plugged in to a snap-on code reader not a specific VAG one.
The only thing that brought up was something to do with the auxillary heater.
Im in Bolton.
Posted : 19/03/2014 8:16 am
My brother had to replace the camshaft in his at similar mileage, lobes where worn badly! It doesn't sound that bad but I'd start with glow plugs as unburt diesel is probably the cause on start up.
Posted : 19/03/2014 10:30 am
Could well be one or more glow plugs have failed, but this is also a symptom of poor fuel atomisation caused by worn injectors. Basically, a diesel squirts it's fuel into the chamber at very very high pressure through a series of tiny but carefully profiles holes in the nozzle. This fuel is effectively atomised into as fine a "mist" as possible, so it can ignite and burn rapidly. Because a diesel engine uses compression pressure to ignite its fuel (no spark plugs) when it is cold, the "end of compression" temperature may not be quite high enough to start the fuel charge burning properly. Old indirectly injected diesels which had much much lower injection pressures used to struggle to start well at low temps often failing to start at all below around -10degc etc, but the modern high pressure ones, like your PD engine, are much better, and when in good condition will start down to around -25degC without assistance (and on "winter" grade diesel).
But, things like the pump and injectors do wear. They operate under huge loads and typically, after around 100kmiles the injector nozzles will no longer be properly atomising the fuel. When the engine is warm this doesn't matter, as there is plenty of temperature in the "hot" engine to light and burn the fuel. You might get a bit more black smoke sometimes under transients, but most drivers don't notice that. However, when cold, the poorly atomised fuel will be difficult to light, and on starting an entire cylinder or more may fail to fire, and that unburnt fuel will be ejected out into the exhaust, where it will burn very slowly and at low temp, causing a lot of blue/grey smoke to be created (interestingly, the red arrows use a diesel injection system into the tail pipe of their jet engined Hawk aircraft to make their smoke trails so typical of their displays!)
Unfortunately, to "fix" this issue requires replacement (or reconditioning) of your injectors, which is an expensive proposition (typically £100 per injector without at labour costs).
So, get the glow plugs checked, if they are easy to remove this is very easy to do (google it), but in some engines they have been known to seize into the head causing issues (same with injectors). If these are fine, and no smoke is generated when doing a warm start or when driving the car normally, then i'm afraid it's "new" injector time....
BTW. no damage is being caused to the car when it runs rough and smokes like that at start, it just looks crap to your neighbours!
Posted : 19/03/2014 11:05 am
EXTRA: "Glow plugs are only used when really cold" is not true of modern Common rail cars, they will be activated even for 25degC starts (briefly) to ensure low particulate emissions, and even be activated during a long (>5sec) trailing throttle event(where the engine is just pumping cold air through itself) to ensure a clean "refire" when the throttle is re-applied etc.
Posted : 19/03/2014 11:07 am
Cheers for that Maxtorque
If it is the injectors, Will they suddenly fail if they are left or will the smoking just gradually get worse?
Posted : 19/03/2014 12:10 pm
+1, interesting reply - my Megane has just gone into the garage to get its injectors looked at, exactly the same symptoms (lots of smoke when the engine was cold, less when it had been running for a while) plus the real giveaway: a message on the dash telling me to get them looked at 🙂
Also noted less power than usual, I'm guessing if a cylinder is not firing properly that would be expected.
Posted : 19/03/2014 12:19 pm
OP - Try changing the fuel filter first, it might have been missed at the last service.
Who is doing your servicing? As incorrect spec oil will also give similar symptoms (Maybe someone used Ford spec oil on your VW engine?)
Posted : 19/03/2014 12:27 pm
There are no warning lights on the dash and no loss of power or black smoke.
Glow plug light comes on when ignition is turned on and goes off after a couple of seconds.
Would sticking some Diesel treatment in have any benefit?
Local garage serviced it last so I dont know what oil was used. What is the difference between ford and VW oil?
Posted : 19/03/2014 12:35 pm
The wiring loom to the injectors can fail, easy to change. Could still be injectors, mail me I may have some. Would need to see if they are compatible.
Why would the wrong spec oil cause a misfire? Although PD's do need the "proper" oil due to camshaft design with the Injectors. If the engine had been run enough to cause damage it wouldn't get any better once the cam followers had worn out.
The PD engine isn't a common rail injection system. It has unit injectors which are given a helping hand with pressure from the camshaft.
Posted : 19/03/2014 12:40 pm
My Golf does exactly this and starts doing it about 1500-2000 miles
before it's next service - post service it's a peach again ...
Coincedence ???
Posted : 19/03/2014 12:46 pm
This is what I was thinking. When you say 'rough' on starting, do you mean noisy as in clacky clacky, or rough running like cough splutter?
I'm not a mechanic but I'd expect worn injector nozzles to give a bit more smoke at full throttle. Also - did this start happening suddenly? Bad injector nozzles would give reduced power and economy gradually I think.
Posted : 19/03/2014 1:02 pm
Molgrips
Its a clacky agricultural noise.
Posted : 19/03/2014 1:05 pm
Have you checked the oil level?
Posted : 19/03/2014 1:10 pm
not recently - you think it may need topping up?
I'll check it tonight.
Posted : 19/03/2014 1:13 pm
Empirical data.
He didn't say misfire, he said running rough. Ford diesel spec is usually 5w-30, I don't know what VW spec is (or if this engine has been adjusted by Ford for their vehicle), I do know that on my similar age TDDI that was starting in a similar rough fashion, it got worse in the cold when I serviced the car using a 10w-40 I'd been given in error, smoke emissions were 7.98.
I changed the oil to 5w-30 spec and it was much better but not brilliant. Replaced the Fuel filter and it was starting straight away without any roughness or smoke, smoke emissons are down to 1.87.
On a scale of expense, 20 mins changing a £20 fuel filter with £2 quids worth diesel, then changing £50 of oil (hell, with another £30 of oil and air filters) is a lot cheaper than injectors, glow plugs etc etc.
Posted : 19/03/2014 2:07 pm
If there's not enough oil the tappets will sound very noisy. This can happen for a few seconds if the oil's drained out of them. Maybe if the oil level was marginal this might happen.. easy to check I guess.
Posted : 19/03/2014 3:48 pm
Glow plugs! It also helps to run 0-30w oil for start up clatter. Run some STP injector diesel cleaner through twice a year and she'll be fine. Just be very careful and finger insert the glow plugs to ensure you don't cross thread them as it's easily done.
Posted : 19/03/2014 4:03 pm
Plumes of white smoke briefly and noise is what the early 2.0 TDIs tended to do when the cylinder heads cracked and slowly leaked water into a cylinder.
White smoke: water
Black/grey: fuel
Blue: oil
However, yours is the 1.9 and usually bombproof. Check under the oil cap for milkshake in case the cylinder head gasket is going.
Otherwise it's probably injectors. Go for an Italian tune up.
Posted : 19/03/2014 5:24 pm
Posted : 19/03/2014 5:34 pm
White smoke is also unburned diesel. It smells of diesel too.
Posted : 19/03/2014 6:00 pm
Glowwwwplugggsss. Had self same failure on my 1998 passat Tdi. They are the cheapest fix to start with before considering injectors! If there is no signs of any head gasket leaks and the smoke clears within a minute or so of starting along with the diesel knock go with my diagnosis. A set is about £30 quid I think.
Posted : 19/03/2014 7:48 pm
Try a simple free test . Switch on ignition , wait for 1 minute then start the car normally. If your glow plugs / glow plug relay or battery are not working at 100% the extra burn time gives even a failing glow plug time to heat through .
The car should start instantly and maybe run a little smoother than usual.
It does sound as if you have multiple issues of a wonky glow plug and a sticky valve that clatters on start up, then once lubed ( 3 secs or so ) quietens down.
Posted : 19/03/2014 8:02 pm
Update.
I have checked glow plugs with a glow plug analyser courtesy of a neighbour. They all come up as ok although I did notice a couple took a few seconds longer to get there.
Checked oil and its bang on max and no signs of head gasket failure. As said earlier though, I can't say if its PD engine specific.
Suppose next step is to drop the oil and change oil and fuel filters?
Car always starts instantly. Just with a cloud if white smoke and the clatter roughness for a few seconds when it's cold.
Posted : 19/03/2014 8:17 pm
Glow plugs if they are even a bit under temperature the engine will not burn the diesel thoroughly in the two affected pots!!!!
Posted : 19/03/2014 8:23 pm
How does the analyser work? On individual plugs not connected to the cars electric circuit or with plug out exposed to the air?
Posted : 19/03/2014 8:26 pm
Eight seconds maximum for relay to switch off glowplugs and you should hear it click off. It it takes anymore than a few seconds for the glowplugs to be up to temperature they are done for. If you wait for them to disintegrate in the pots then you really will be in for a big bill! Just pull the plugs and examine them if you want to confirm it's not them before you buy any!
Posted : 19/03/2014 8:28 pm
Removed the busbar. Analyser is a unit similar to a multimeter. One croc clip went to battery positive, another to earth, then it has a wand that you touch to the top of the glow plug while its in situ. Display shows 16a then goes green (ok) when glow plug is at temperature.
Posted : 19/03/2014 8:32 pm
Trust me I would still pull the glowplugs. If you want to keep repairs cheap just replace the two sluggish ones. Are all the wiring connections okay too as that style multimeter will not pick up any problems. How many seconds for each plug to be up to temp?
I had the occasional sticking injector caused by cheap fuel so every fourth tank I used to use a tank of posh diesel ie v power. I kept my passat running for 250000 miles over 11 years before my daughters other half had it for another year before he sold it on and it was still going strong. I just hate the thought of you wasting your time doing other stuff first when I am convinced it's the glowplugs.
Posted : 19/03/2014 8:43 pm
The thing about glowplugs, is that they're not that expensive or difficult to replace, til one of them breaks off in the engine.
Posted : 19/03/2014 8:46 pm
So is it best to remove glow plugs when the engine is hot after a run? Don't want to snap one.
Squirt if wd40 or similar worth trying?
Posted : 19/03/2014 8:53 pm
Have you tried two goes at pre heating the glow plugs before the engine turns over to see if it makes a difference ?
Posted : 19/03/2014 9:01 pm
My local garage snapped off the oil dipstick when changing mine . Then charged me for a new one .
Also run PD's into the 300K zone . Does your neighbour have a battery checker ? Could be low on volts or amps making the glow plugs less effective.
Still think its 1 bad plug plus a dry tappet , and at the end of the day so what . It smokes a little on start up , There might be a tiny amount of bore washing from un burnt fuel but its negligable . Summers coming , weather is warming up , making life easier for the battery and starter motor .
Save up a few quid , buy some Bosch glow plugs and whizz em in , nothing really bad is going to happen in the next few thousand miles if you misfire on 1 cyclinder for 3 or 4 engine revolutions.
Posted : 19/03/2014 9:04 pm
Not sure it's the glow plugs. If it starts immediately in all weathers, how can it be?
Can you post up a video with sound?
Posted : 19/03/2014 9:06 pm
I'll try and get video tomorrow am.
Always fires into life after 1 crank.
Cloud of white smoke
Rough running for max 5 seconds
Then everything is fine - no smoke and idles fine
Posted : 19/03/2014 9:14 pm
One or more failed glow plugs so the engine starts on three cylinders with the other one joining in when it gets some heat into it. It's easy to check with a clamp meter.
Posted : 19/03/2014 9:41 pm
If you don't mind waiting a couple of days, and have an XP or Win 7 laptop, get a USB diagnostic lead from Ebay, download VCDS-Lite. You'll be able to read your codes. Your generic reader is like mine- doesn't see specific VW codes (there are thousands.)
Here's mine:
http://www.ebay.co.uk/itm/271036790042?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2648
VCDS-Lite:
http://www.ross-tech.com/vcds-lite/download/
I would agree with an earlier poster- it sounds like one or more slow plugs to me. You'll be using those plugs much more than you think. Get VCDS, it will make troubleshooting so much easier. The 'shareware' version is free and you'll be enlightened.
Update.....
I renewed all the glow plugs yesterday for Bosch Duraterm ones.
Started the car this morning and it (as usual) started 1st time.
However the puff if smoke and engine clatter are still there.
So - what next?
Do we just ignore it as it starts and drives fine? Is it a trait of the PD engine?
Posted : 30/03/2014 11:07 am
Dunno about the smoke (although mine is quite smelly on start up), but mine is clattery on start up for a minute or so (1.9 Tdi).
Posted : 30/03/2014 11:42 am
If it's 03 I don't think it will be a PD engine... 😐
White smoke from a TDi Galaxy / Sharran / Alhambra is 99% the Auxilliary heater, under the passenger side rear wheel arch. It's only supposed to try & work below 10degC though. They have a heater plug that burns out. If working fine should sound like a jet engine on a cold day.
For the clattering, watch the aux belt when someone starts the car from cold. They have a clutch type pulley on the alternator. These seize up, & can sometimes take a minute to free up from cold, but usually only when it's idling. It allows the alternator to free wheel. The belt will be jumping around, but then run free. Sounds clattery while it's bouncing. Alternator out to change, & a special tool to change. Several types of pulley, so count the teeth & measure dia before buying.
Other than that, the CAT, loose stuff in there bouncing around ?
Post this on FGOC.CO.UK
[i]Daz[/i] or [i]Serviceford[/i] are top blokes, & know these cars inside out.
Posted : 30/03/2014 12:20 pm
Aux heater works fine. No smoke from that. Just a puff from exhaust on cold start which immediately stops.
I'll check the alternator belt.
Posted : 30/03/2014 12:27 pm
Temperature sender,located on the back of the block nearest to the passenger side. Swap out the black original for the green replacement unit. Couple of quid from Eurocarparts. This fools the ecu by giving a false temperature and therefore wrong fuelling at start up.
Posted : 30/03/2014 7:55 pm
My dads focus 1.8 tdci would start with all the glow plugs knackered. The injection system is so accurate it still starts but runs like a bag of hammers till it warms up. It would still easily start on one or two plugs but the unburnt diesel would come out as white smoke. Check the wiring they can draw quite a lot of current. Check for signs of burning of the wiring.
Posted : 30/03/2014 10:45 pm
My 08 2.0 pd passat does exactly the same as what you describe nomad...
did you get it sorted?
Posted : 05/04/2014 11:34 am
