Hi,
I'm in the process of planning a large (not by McMoonter standards) wood store. It will be approximately the length of our garage and about 1.5-2.5m deep. I've been thinking about the base and toying with concreting posts in to the ground, laying a slab, putting the timber straight on the ground then i came across decking blocks...something like this:
https://www.wrekinconcreteproducts.co.uk/products/wrekin-concrete-products-decking-block/
They seem like a lot less phaff than the other options and hopefully more long lasting than having the timber posts go into the ground.
Are there any downside to these types of blocks?
Do they have an ability to level up or down? This may not be an issue for you.
They seem like a good solution to keeping your floor off the ground. I assume you've got to level the area first though and have some sort of stable surface for them to sit on.
I always concrete a small pad then lay a 4" block flat, these will give you the same outcome but at a fair bit more cost no doubt. What are you bearing the individual blocks themselves on to?
matt_outandabout
Subscriber
Aye, if you kill enough of your enemies with one it'll gain +1 to charisma.
I assume you’ve got to level the area first though and have some sort of stable surface for them to sit on.
The ground is right on top of a hill with very free draining gravel heavy / sandy soil. My plan would be to dig down, compact the soil with a block of wood and a lump hammer and site these deck blocks level. Then add some weed proof membrane before getting busy with the 2x4's.
Welcome to any other suggestions!
Also what sort of timber should i go for? I'm no expert but a quick google shows various grades/strengths...
C16/C24
Tanalised
Treated
I[m not familiar with all these terms
For a log store you just want treated (tannalised) timber, not posh stuff (structural grading c24/c16).
See if you have a local sawmill - mine charges half what the builders merchants/Wickes wanted.
Most timber is c16 minimum anyway, my merchant now sends all joists out as c24. Main thing as moab states is it needs to be treated.
And don't scrimp on the bearers, one on each corner won't be enough if using say 4x2.
C16 and C24 are strength grading standards for rafters etc - not needed in your case.
Nice idea about the decking blocks - I may use that for my next project!
