Dear Sparkies - Neo...
[Closed] Dear Sparkies - Neon indicators yay or nay?
9 Users
 Sui
I'll head off the usual, get a sparky, comment first with - im just changing some sockets around in new kitchen - i wired the house with a sparky so quite confidient with what im doing..
So - i have 2 x ovens on one radial direct from fuse board going through a local isolator (one each) as well as an induction on it's own radail direct from board via an isolator. All of the isolators ive currently got are cheap nasty white ones with big red neon indicators.. The missus is abot anti random lights on everywhere, so my question is are neon indicators a must have under wiring regs?
ta
Posted : 26/05/2022 10:41 am
The isolators for our ovens do not have lights plus they are tucked away at the back of a base unit cupboard near the ovens - because who the hell wants to see them?!
(kitchen installed 3 years ago and 100% on electrical spec)
Posted : 26/05/2022 10:47 am
 Sui
cheers sharkbait - seems to be a lack of ones without the neon light - mayb as i want them in a light copper/rose gold colour..
Posted : 26/05/2022 10:56 am
Can you remove the bulb?
Posted : 26/05/2022 10:58 am
Bit of gaffa over the bulb will sort it! 👍
Posted : 26/05/2022 11:03 am
Or put it over your missus' specs, she won't notice the lamp.
Posted : 26/05/2022 11:08 am
I'm not sure the wiring regs require isolators anymore... so from that, any you do choose to fit wouldn't require any form of lighting, and just need to be rated for the cable/current.
Posted : 26/05/2022 11:11 am
 Sui
thanks @funkynick, this was what i thought i had read. Cables are fine, they are over-rated (both 8 +10mm) for potnetial loads over the longish run - b'stard to wire up though - much swearing..
Posted : 26/05/2022 11:20 am
BS7671 (Wiring Regs) do not require any neon indicators on isolators.
Does your isolator have a socket integrated into it? Does it take up a single module or a double?
I’m not sure the wiring regs require isolators anymore
You should maintain a local point of isolation for the appliances
Posted : 26/05/2022 11:28 am
b’stard to wire up though
After you tightened BOTH screws in each terminal (make sure the bottom one has bitten down into the copper, and obviously that you've stripped enough insulation back to ensure it goes right to the bottom) so that'll be two in the L and two in the N, give the conductor a wiggle to settle it into the terminal, then give each another nip to make sure. There's a lot of current going through the terminals and that's what causes the arcing and destroys the termination point if it's in any way slightly loose. Then when settling the faceplate back into the backbox make sure the cables are dressed in the back to ensure there's no sideways strain on them and that they're not pushing against anything. You'll probably have to nestle the isolator(s) back gently to allow the cables to find their own space behind but don't force it as if you push them against something hard it may cause the insulation to thin over time and eventually trip the rcd, which'll be a pain. Make sure there are grommets in the box too, if there's not already.
Posted : 26/05/2022 11:38 am
 Sui
@creakingdoor, thanks for reply. It's a single faceplate/module - no socket. They are located at worksurface level, so not tucked away, though i did think about having a blanking plate on a unit and having them all located there -got too complicated for me).. I've seen white ones sans neon.indicator but the fancy ones all seem to have lights.
Posted : 26/05/2022 11:40 am
 Sui
ha grommets - i've had my hands slapped over that before i plastered - got loads of the bu88ers left..
Posted : 26/05/2022 11:42 am
It's very straightforward to remove the whole neon module from the back of the isolators (or at least it used to be when I used to get my hands dirty for a living!)
Posted : 26/05/2022 11:43 am
Just as another view, if you don't want random lights on everywhere you can switch them off. I've taking to switching our oven and microwave off at the wall rather than having it show me a clock that I never use. Just turn it on, use it, turn it off. I suspect the standby current is minimal but no harm in dropping it to zero. Neon light might be a handy reminder.
Posted : 26/05/2022 11:45 am
 Sui
creakingdoor
It’s very straightforward to remove the whole neon module from the back of the isolators (or at least it used to be when I used to get my hands dirty for a living!)
a little snip of the wires will do the job. i may just suck it up and use a dark marker over the lamps, some models seem to have relatively small ones..
https://www.screwfix.com/p/schneider-electric-lisse-deco-50a-1-gang-dp-cooker-switch-copper-with-led-with-white-inserts/746HX?tc=PB6&ds_kid=92700055281954484&ds_rl=1249401&gclid=CjwKCAjwyryUBhBSEiwAGN5OCFAEn6-TwAWKsOcotMghCL5meb7HmIAS6wqNxKsyCjGJXucl8MHPWhoCGv8QAvD_BwE&gclsrc=aw.ds
not like these
https://www.screwfix.com/p/lap-45a-1-gang-dp-cooker-switch-white-with-neon/49779
uurgghh
Posted : 26/05/2022 11:47 am
 Sui
nickjb
Just as another view, if you don’t want random lights on everywhere you can switch them off. I’ve taking to switching our oven and microwave off at the wall rather than having it show me a clock that I never use. Just turn it on, use it, turn it off. I suspect the standby current is minimal but no harm in dropping it to zero. Neon light might be a handy reminder.
cant do that, they've got wifi! (why i need wifi is anyones guess, other than the meat probe). The missus is famed for going round switching everything off - when we first met she kept turning the soddin router off leaving me confused as to why there was no internet all the time.
edit to add -we (me) now employ the " see no evil, hear no evil" mantra...
Posted : 26/05/2022 11:50 am
Or a similar vein, did anybody else's dad used to put a cloth over the VCR player (early 80s) so that the clock couldn't be seen by potential burglars looking in through the window at night (even though the curtains were closed)?
 Sui
creakingdoor
Or a similar vein, did anybody else’s dad used to put a cloth over the VCR player (early 80s) so that the clock couldn’t be seen by potential burglars looking in through the window at night (even though the curtains were closed)?
LO - YES!
Posted : 26/05/2022 11:51 am
2x 10mm and a load cable in a single box accessory! Good luck, that’s gonna be a nightmare to connect, maybe don’t get flat plate accessories to replace!
Posted : 26/05/2022 11:52 am
The big fat neon ones are easy to remove, not sure about the LED ones as the wiring may be different and more internal
Posted : 26/05/2022 11:53 am
Just to clarify... I wasn't suggesting that it's a good idea to remove the isolators, just that as they are not 'required' then there can be no requirements about illumination.
I'd always want some local isolation, we keep our cooker/oven etc turned off unless we are actually using it, just to stop little fingers playing, or my wife's bum from turning the hobs on!!
Posted : 26/05/2022 11:54 am
Gives an extra 10mm
Posted : 26/05/2022 11:55 am
I wasn’t suggesting that it’s a good idea to remove the isolators
or my wife’s bum from turning the hobs on
Twerking while cooking! 😅
Posted : 26/05/2022 11:57 am
It takes me 5 mins to set up the time, day, month, year on 2 ovens (and of course they have to be in sync) so switching off is not an option!!
Posted : 26/05/2022 12:02 pm
 Sui
markspark
hence the swearing - though they are very deep back boxes.. - fairly certian mr sparky was been overly cautious with the induction one (the others are only 8mm) - the run is only about 30meters..
Posted : 26/05/2022 12:06 pm
it takes me 5 mins to set up the time, day, month, year on 2 ovens (and of course they have to be in sync) so switching off is not an option!!
plus some ovens won't heat up until the clock has been set which led to no end of teeth gnashing in the Mrs' old rental place after a power cut 🤣
Posted : 26/05/2022 12:07 pm
plus some ovens won’t heat up until the clock has been set
Yep.... which is why I have to go through setting everything on both ovens (plus they're the only 'clocks' in the kitchen).
Posted : 26/05/2022 12:17 pm
Some single ovens only are rated about 3kw (13A) anyway (many are only 2kw (8.6A)), usually those where the grill and oven can't be used simultaneously (due to the way the switching works). A 6mm (it's not 8mm) will be fine as that's good for over 30A, depending on the way the cable has been routed (kept out of insulation), although if your sparky has done a good job that shouldn't be an issue.
Posted : 26/05/2022 12:18 pm
Ours was unplugged overnight along with everything else in the house!
Not that there was much TV on after about 11pm in the 80s.
Posted : 26/05/2022 1:46 pm
Does it really need to be set right though? Ours needs to be 'set' to work, just hold the clock button for 1 second and it'll set to 12:00. Turn it off when done and you'll never know it was wrong. Leaving it on 24 hours so it can connect to the wifi does seem especially crazy, though. Lucky there isn't an energy crisis, I suppose 🙂
Posted : 26/05/2022 2:23 pm
