Im running KCNC steel skewers on Hope Pro2 hubs with my Ti road frame, and im having trouble with the skewers slipping.
I've put the rear under as much tension as I can manage, but when stomping up a steep climb today the hub popped out of the left side drop out.
I had the same thing happen several times and had to resort to stopping standing when climbing.
Im guessing that im experiencing a bit of flex to the rear of the frame, being Ti, but should it be enough to jump right out of the drop out under tension?
Or, are the KCNC skewers rubbish?
I've just fitted a boggo standard QR in the hope the mechanism will be tighter, but havent time to test it.
Anyone else experienced similar?
Ive found my KCNC seat clamp to be pants too, along with a Hope clamp on my MTB, so im hoping Salsa skewers may be up to the clamping forces required..
Less stomping?
The skewers are probably rubbish. No problems with Campag skewers on mine.
i've never had issues before with any other skewers, its just got me worried being my first Ti road frame
I was going to give you a quick fix(even with dodgy skewers),but as you used the term darkside,you have just lost that option 😉 🙂
sorry, i thought it was mandatory
Shimano skewers, end of.
horizontal or vertical dropouts?
Decent steel, shimano/campag make a lot more sense for the rear skewer than anything lightweight.
I've been riding a Ti road frame for a couple of years and had no such problems. But then I use Shimano skewers.
And the moral of this story is. . . . ?
Less stomping?
What Ti frame is it? I can't be of any assistance whatsoever but I'm just interested.
However, Shimano skewers have never given me any problems on any bike. Any skewers with a plastic bit at the cam have all loosened over time.
I use KCNC steel qrs on my road bikes, they do have an odd cam. As you push the lever over to tighten them up they loosen up when fully closed.
So I start with them tighter than other qrs before closing the lever. Not had any probs with them so far but I do wonder how long they will last.
I used to have Salsa QRs, not very impressive. Shimano obviously, or I like the Halo hex ones, they weigh nowt and they seem just as secure.
Frame material in itself is not causing the problem.
The skewers are most likely IMO.
Odd that the left side poped out, when a rear wheel slips due to insecure rear wheel its usually the right side will be pulled forward by the chain.
might be a shit dropout design
My old ProLite lucianos did this with my bike (alu/carbon stays) and I always put it down to the drop out design. Got Fulcrum (campag?) skewers now and have had no such occurence,
While you are waiting for new skewers have a look to make sure the drop out isn't bent. Does seem weird.
here's the drop out - Planet X Ti Pro frame.
Have also had trouble with getting a King headset to sit perfectly flush, which PX promised was 'checked & quality controlled'. TBH i'm getting a sinking feeling over this and other issues i've had with said brand
Just to add, all components are brand new.
/\ this. its like the last 2mm of lever movement begins to release tension?..
My mate had this problem with his van nic titanium frame, he had to us the Allen bolt type
It solved his and could be your better option
typical, mines the Van Nic made PX frame..
My road frame is a Van Nic made Van Nic frame.
ok..
Doh, I typed Salsa up the page instead of KCNC, I'm a dope.
Just to add to that though- I'm still using the QR on one bike, and it's crap. Looks nice, weighs nowt, but crap.
Similar issue with X-lite camlock skewers on a Tinbred. The little serrations on the skewers that are supposed to grip the dropout had been flattened/worn down. I didn't have the heart to take an angel grinder to a new frame to roughen the dropouts so bunged a SHiamno skewer in with steel ends and presto, problem solved. I also contemplated using star washers to provide some extra grip between frame and skewer. Maybe Planet X could start putting some engraving on the drop outs to grip the skewers?
....take an angel grinder to a new frame...
I gotta me one of those.....GRRRRRR!!!
thanks guys - fingers crossed a nice Salsa or Shimano QR will do the job
Change the skewers. Boring as it is a Shimano or Campag QR will probably solve your issue.
