Damaged laminate wo...
[Closed] Damaged laminate worktop- how to seal?
6 Users
Water ingress behind the sink has led to cracking of an area approx 3ft long. I've stripped this back and the core of the worktop still seems sound. The damge ranges from about 12cm to 6cm deep along the length.
We will be doing a full kitchen replacement in the next year, so I am just looking at how best to prolong the current life. I did pick up a tube of Colorfill but its not going to provide adequate coverage (I can get other tubes if req!)
Anything I can "paint" on that what be suitable? Matching the current pale grey/dark grey/pink speckle finish not important!
Thanks in advance..
Posted : 08/06/2021 8:12 pm
Epoxy resin.
You can even die it.
Posted : 08/06/2021 8:23 pm
Epoxy, PVA or silicon
Posted : 08/06/2021 9:40 pm
Ronseal 2 part wood filler, £17 for 1kg at screwfix
Posted : 09/06/2021 12:11 am
Please believe me when I say Gorilla Tape. I ran out of the iron-on strip when I was doing the edging on our worktop, having made more cuts than expected and used a piece "temporarily". 5 years later it's still in good shape.
Posted : 09/06/2021 1:40 am
 tomd
Maybe an idea would be to use a router or be patient with a chisel and cut a straight line along the back of the worktop and router / chisel out a uniform depth so you're left with a straight edged and flat bottomed "channel" to fill. A bit of ply could be cut to fit and with a bit of filler and paint might look tolerable for a year.
Posted : 09/06/2021 11:19 am
