Can anyone recommend some high capacity rechargeable D cell batteries. Most of the ones I've found so far only seem to be around 2500 mAh (about the same as a AA cell), I've found a few 10000 mAh but they seem mighty expensive.
Haha, classic film.
If you can't find D cells at a resonable price these could be an alternative solution....
http://www.ebay.co.uk/itm/4-x-2AA-to-D-Battery-Adapter-Converter-Case-New-/110740710716
I'd rather have somewhere near the 10000 mAh capacity.
Maplin have 2x 5,000mAh for £9.99
Otherwise you are looking at £10 each for 10,000mAh
The price is about right tbh as thats 4x a high power AA cell in one D cell.
I could buy a lot of non-rechargeable's for £60 + the cost of a charger 🙁
what are they for?
DAB/WiFi radio, quite heavy power consumption.
what voltage does it need?
Might be possible to rig up a lithium ion battery pack.
Given the drip fed info, I'd guess a range of 9V to 6V (6 cells). Which would suit a LiIon pack very nicely. Mind you, a 10Ah LiIon pack isn't going to be that cheap either.
Did anyone else think:
[img] http://katysclutter.typepad.com/.a/6a00e5536d1ffb8833016763a963c0970b-500wi [/img]
emergency lighting replacement pack from electrical wholesalers ... break up the pack
You're not kidding! How big is it, about the size of a suitcase?DAB/WiFi radio, quite heavy power consumption.
I've been using converters and AA cells for the last few years. Keep it cheap and simple.
