Cunning solutions t...
[Closed] Cunning solutions to return empty car hire when only doing limited mileage?
9 Users
 bubs
Is taking a siphon my best option?
Posted : 05/07/2016 7:07 pm
Full to full is your best option.
Posted : 05/07/2016 7:08 pm
 bubs
Unfortunately full to full is not an option in Jersey (even where it is elsewhere).
Posted : 05/07/2016 7:22 pm
Isn't petrol dirt cheap in Jersey?
Edit: Googled it, it's cheaper but not as cheap as I remember...
Posted : 05/07/2016 7:44 pm
Modern cars have an anti siphon thingy fitted .
Posted : 05/07/2016 7:50 pm
 bubs
Damn it. 👿
Posted : 05/07/2016 7:51 pm
Just unplug the hose from the end of the injector rail and aim it into a jerry can whilst getting a mate to keep turning the key....doesnt take long but isnt much good for the battery...not that would bother you im sure 😉
Posted : 05/07/2016 7:54 pm
Suck it up.
Posted : 05/07/2016 7:56 pm
When filling up keep the ignition key turned on and you will see the fuel dial move, just stop pump, check dial and top up to required amount.
Posted : 05/07/2016 8:00 pm
Up on blocks. Brick on the accelerator. What could go wrong!
Posted : 05/07/2016 8:03 pm
Some fuel gauges get confused if you try to fill up with ignition on. (Or, at least they do if you fill up, or pump from a secondary tank, whilst the engine is running)
I once partially emptied a brimmed petrol tank (the connecter in the lift pump was overheating and the petrol was leaking out alongside the electrical pins when driven) by running a tube from the lift pump to the jerry can and repeatedly turning on the ignition to make the pump prime the fuel system.
Posted : 05/07/2016 8:17 pm
How odd. Dunno then.
Posted : 05/07/2016 8:18 pm
