Crimping tools
[Closed] Crimping tools
8 Users
I'm sure I asked something similar before but I cannot find it.  And these are different connectors.
How can I find a crimping tool for these?
They're sold as VAG connector pins.
Posted : 17/07/2018 12:53 pm
Have a Google for molex crimp tool. You want something that looks like this:
Posted : 17/07/2018 1:02 pm
You can get the generic knipex ones from RS components, not cheap though.
Posted : 17/07/2018 1:06 pm
Last VAG stuff (MAF pins) I looked at used JPT (Junior Power Timer) and a Durite 0-703-52 ratchet crimping tool makes nice job if you are willing to pay for it.
Posted : 17/07/2018 1:30 pm
I've always used pliers for that sort of connector.
Posted : 17/07/2018 2:01 pm
 Del
as above they look like molex to me. if you just need to do a few and don't have the correct tool you're probably better off soldering leads on carefully, then squeezing the strain reliefs ( the two 'wings' top ) down on the coating. alternatively hack off the existing crimps/shell and splice the wiring.
do you have the shells/housings? they can be difficult to get the old crimps out of.
if you can measure them, and if we have them, i can prep some leads for you with the crimps fitted if that helps.
Posted : 17/07/2018 2:02 pm
Unless you have loads of these connections to do I'd just fold the tabs over and close with pliers. The crimp tool will be 30 quid or so?
Posted : 17/07/2018 3:40 pm
Pop into the main dealer and ask if you can crimp one off?
Posted : 17/07/2018 10:10 pm
