Copying selected mu...
[Closed] Copying selected music files to sd
7 Users
Am wanting to put music files to my phone. I got itunes to create lossless and mp3 versions of each track - but they are both in the same folder for each album (i.e. not separate folder for each file type) and so I can't copy and past the mp3s over - I have to copy the lot into a new folder, then delete the lossless, then copy to sd?
Or is there an easier/quicker way?
Posted : 26/10/2011 9:23 am
cant you just sort the list by type?
Posted : 26/10/2011 9:26 am
There's some free software called ycopy, within which you can specify rules.
So you tell it to copy from the source folder to the destination folder, but only .mp3
http://download.cnet.com/Ycopy/3000-2248_4-10494065.html
Posted : 26/10/2011 9:34 am
 DrJ
I thought it was simple. At least that's what the Apple-phobics tell us.
Posted : 26/10/2011 9:36 am
I guess it's cos I am messing with both systems...
Posted : 26/10/2011 9:38 am
Select the songs you want in the list in iTunes, drag and drop onto the folder for the memory card.
Job done.
Rachel
Posted : 26/10/2011 9:40 am
View / Arrange Icons By / Type.
(Or, Search, *.mp3)
Posted : 26/10/2011 9:41 am
At last, something Windows 7 does well!
Search, as Cougar says on the top level folder. All mp3s will result.
Unless of course you want to keep the folders... unless of course you're using a Mac...
Posted : 26/10/2011 9:57 am
ta Rachel - trying that.
Cougar - would that copy folders too? Seems not - which is exactly what I was needing to achieve! Don't you and DezB read?
Posted : 26/10/2011 10:36 am
Argh Rachel's method is a similar FAIL!
Looks like RTTPOS will save teh day.
Posted : 26/10/2011 10:40 am
I read, it looked like your issue was that you were seeing
track1.fla
track1.mp3
track2.fla
track2.mp3
track1.fla
track2.mp3
...in a folder, you never mentioned anything about multiple folders, or copying folders. WTF do you need subfolders on your phone for anyway?
I have a way of doing what you're trying to achieve, but TBH if you're going to be a nobber when people are trying to help, you can work it out yourself.
Posted : 26/10/2011 10:54 am
RTTPOS saved teh day.
Posted : 26/10/2011 11:19 am
Phone only identifies albums if they are in separate folders - apologies if this was not made clear.
Posted : 26/10/2011 11:20 am
[i]Cougar - would that copy folders too? Seems not - which is exactly what I was needing to achieve! Don't you and DezB read?[/i]
Where? Where does it say you want to keep the folders??
[edit] Obviously I don't read, or I would've seen your previous post !
Posted : 26/10/2011 11:39 am
