Cooker Fixer
[Closed] Cooker Fixer
7 Users
My electric cooker has gone wrong. Do I just call an electrician or do I call some other kind of specialist?
Posted : 09/09/2016 5:55 pm
Call a specialist appliance engineer. An electrician will not have the parts to do it and probably not the expertise.
Posted : 09/09/2016 6:53 pm
MTFU and replace the element?
Posted : 09/09/2016 6:59 pm
Level 1 Manliness was knowing it was not the element.
Posted : 09/09/2016 7:23 pm
Google 'oven repairs near me?'
Posted : 09/09/2016 8:24 pm
But, where do you live?
Posted : 09/09/2016 9:22 pm
Have the model number and serial number ready when you phone the repairers. You'll find them on the rating plate, a little silver sticker/badge that's almost certainly around the main oven door aperture. Check for other numbers as well, Electrolux group have a PNC code, Bosch an FD.. number etc.
A good firm will ask you several questions before calling out to try and diagnose the fault. Having all the details as above will save them time and you money.
Posted : 09/09/2016 9:26 pm
And be ready to price up a new oven. I was recently quoted £85 +vat call out including half an hour labour, then 45+vat per half hour and parts to fix two ignitions on gas cooker. "It'll take about an hour plus 20 i parts" he said "I'll be making do with matches." i said
Posted : 09/09/2016 10:27 pm
Anything gas will be a lot of money to have repaired thanks to all the regulations associated with it.
I don't work with gas, only electric stuff as it's not economical to get set up for gas. We charge under half the prices quoted above.
EDIT: That said we do replace [u]electrical[/u] and [u]mechanical[/u] parts on gas appliances as long as it does no involve touching a single gas carrying component. Ignitors would normally be seperate from the gas lines themselves but then if you're getting quotes from a Gas Safe registered company they will charge Gas Safe registered prices regardless.
Posted : 10/09/2016 11:38 am
thermostat ? even easier DIY fix.
Posted : 10/09/2016 11:41 am
It does look like the overheat thermostat, It doesn't look easy, it's a built in and i think the stat is in the back somewhere
Posted : 12/09/2016 12:15 pm
