Converting movies t...
[Closed] Converting movies to ipad
11 Users
Can anyone recommend a good, quickish, reliable & hopefully free software to convert movies to my ipad to help relieve my night shifts?
Thanks
Posted : 05/02/2016 3:03 pm
Handbrake is a good place to start. Download VLC with it
Posted : 05/02/2016 3:38 pm
Or just use VLC and don't bother converting them - VLC can play just about any format and you can load files into VLC via iTunes (even if iTunes can't play them).
Posted : 05/02/2016 3:39 pm
Just done that very same thing... Drag and drop them into the VLC app thing in iTunes and it pushes the film across to the iPad.
Amazingly it works.
Posted : 05/02/2016 3:42 pm
Does this VLC app handle disney films as i find nearly all my recent films are protected in some form and handbrake etc cant get anywhere near them.
So i download the VLS app on my laptop and i can then drag and drop dvd's to I tunes?
Posted : 05/02/2016 4:19 pm
Plex, and do it differently 😉
Posted : 05/02/2016 4:21 pm
Been using Handbrake here too.
Posted : 05/02/2016 4:41 pm
 MSP
Can handbrake and vlc remove blueray protection? Last time I tried it couldn't.
I buy most of my films through itunes anyway, but some stuff, like the BBC natural history output, I would prefer to buy on blueray. The compression used by apple seems to distort at times (say when looking at "ripply" water it can be quite noticeable).
Posted : 05/02/2016 4:54 pm
Unconverted files are about three times the size of converted films...
I use DVD Decrypter (might still be available somewhere) to rip the DVD. This comes off as a .VOB file, which can be renamed to a .mpg. Ignore the warning.
I then use DVDVideosoft's free converter to convert to a .mp4 - which is not as good as the .mpg on a decent sized television, but is fine on an iPad. I suggest using the setting for the best quality that your iPad will support.
I should like to point out that I own all the DVDs that I have ripped - this is simply for iTunes and the NAS drive.
Posted : 05/02/2016 5:48 pm
If you've using OSX then MakeMKV and Handbrake do a good (although slightly longwinded) job of making a Blu Ray iTunesable.
Posted : 05/02/2016 5:50 pm
I use one of these for my i pad air to import from an usb stick.
Files need to be mp4,create a DCIM folder on the stick,rename video files to an 8 digit number and they go straight in to your photo folder on your i pad.No need for i tunes.[img] [/img]
Posted : 05/02/2016 6:27 pm
VLC did the trick. Simple & fast, job done. Thanks for the info peeps.
Posted : 06/02/2016 3:15 pm
