Is it possible to connect an iPad mini to a TV at all.
If so how do I do it ?
Steve
Yup, one of these:
http://store.apple.com/uk/product/MD826ZM/A/lightning-digital-av-adapter
(and a HDMI cable obviously) or an Apple TV and share the screen/stream over wifi.
Might be able to get a cheaper 3rd party adapter cable, which may or may not work. For the cost of the cable, I'd be looking at an apple TV (if it's just the one screen you want to hook it to).
40£ is a bit steep
Any ideas on after market ones that work ?
Chromecast?
Probably a dumb question, but if you connect the iPad and TV, does it Just Work, and display the screen on the TV, or is there Other Stuff you need to do - settings to adjust etc. ??
Out of curiosity, do those adaptor sallow you to put apps where airplay is disabled eg Sky Go, onto your tv?
As far as I can see from the Apple support site, no, but see my question above - I have no clue what I'm talking about ... 🙁
whats the idea behind this, looking at photos or something? or to act as a smart tv with Netflix & iplyer etc?
We want to do it as I've been given a link to an app called cartoon hd which has loads of movies on. Was hoping to stream these to the TV in the front room.
Will that be possible then with that adaptor linked above ?
Will it be full screen on my TV ?
I have the same app and had the same question. A guy at work has apple TV and he confirmed that you can watch the films via apple TV.
I have wanted one for a while but never really saw the point until using this app.
My only concern is that the app seems to good to be true and wonder how long it will work for.
I don't think the cable is worth buying at £40 when apple TV is only £100 and can do a lot more than just the cable.
No. It works the same way as airplay. If the app doesn't support airplay then the cable won't work.
Edit: just to add that I have both the cable and Apple TV. Cable is great when on holiday for example. If you can play it via Apple TV then you can play it via the cable. If you can't then it won't.
you can pick up a new apple tv for £73. Well worth it as you can link your phone, iPad etc all to the telly
Ah thanks.
Apple TV via Airplay was designed specifically for this task. Streaming BBC iPlayer to the front TV is seamless, even from 2G iPod Shuffle. Apple TC connects to the TV with an HDMI cable.
Im not sure I need Apple tv to be honest, I already have a playstation that has iplayer etc on.
My sky go app won't let me broadcast via hdmi cable
Sky go won't work with anything other than the screen on the device. And it won't work with rooted android devices incase you try and get round it. Bit of a shame really, but I suppose then they wouldn't be able to hammer you for an extra tenner a month for multiroom.
I tried an hdmi cable with my phone for when we were on holiday but no joy, fine with everything else but no sky go.
Later apple mobile products allow you to mirror the screen to the Apple TV via Airplay.
http://support.apple.com/kb/ht5209
