Connecting Bluetoot...
Connecting Bluetooth headphones to stereo
7 Users
I've got some relatively decent Bluetooth headphones that I'd like to connect to my old stereo system.
Appreciate that may be a blasphemous statement to the audiophiles on here! But whilst most the time I will enjoy through my speakers there are occasions when I'm told I need to turn it down so I'd like to have the option of headphones then.
Is it just a case of getting a Bluetooth receiver - if so, how important is the quality? and does anyone have any recommendations on which to buy (or alternative solutions)
Posted : 02/02/2023 4:14 pm
You need a Bluetooth transmitter, not receiver. There are loads on eBay for under £20. I also had to buy a 1/4" to 3.5mm Jack converter as my old amp had a 1/4" headphone socket. Seems to work ok.
Posted : 02/02/2023 4:25 pm
What outputs has your stereo got? What headphones are they and what BT codecs are they capable of?
Posted : 02/02/2023 5:55 pm
If it's bluetooth you might just be better connecting to your phone and streaming if you have the option.  Otherwise it is indeed a transmitter and not a receiver that you need.  If you run your TV through your hifi then you are looking for something that uses aptX low latency such as this
Sennheiser BT T100 – Thomann België
Posted : 02/02/2023 6:13 pm
Your old stereo system may not necessarily have an output...ie something that can connect to a Bluetooth transmitter... Worth checking this first.
Posted : 02/02/2023 6:47 pm
Your old stereo system may not necessarily have an output…ie something that can connect to a Bluetooth transmitter… Worth checking this first.
It would be an unusual stereo system that didn’t have a headphone socket on the front, even high-end kit should have a headphone socket somewhere, real audiophiles like having insanely expensive headphones so like to plug them in somewhere.
I plug mine into my phone, it’s just easier than having a cable stretched across the room to the amp, then having to keep getting up to change CD’s - everything on the phone’s Lossless so no significant difference.
Posted : 02/02/2023 8:17 pm
Thanks all, should’ve said I will continue to use phone for Spotify but this is so I can listen to vinyl on stereo.
Appreciate that might defeat audio quality aspect but still like the sensation of putting a record on rather than just listening to a stream
Posted : 02/02/2023 8:39 pm
If it's got a headphone socket, you are in luck with a bluetooth transmitter. I use a bluetooth receiver on the aux in on my 1986 JVC separates system.
Posted : 02/02/2023 9:02 pm
