Cold weather - boil...
[Closed] Cold weather - boiler don't work properly content..
8 Users
My GloWorm 30Cxi combi boiler failed to ignite over the weekend, due to low pressure.
Via Hive I could see from Friday onwards my house descending beyond the 10 degree frost setting right down to 4 degrees when I got home this morning. Re-pressurised the boiler and heating fired up and the house has warmed nicely over the day.
Come to run some hot water tonight and not a drip. No firing up of the boiler, not a sausage.
Is this the same as the usual 'knock the diverter valve with a hammer' scenario on a normal heating system?
The boiler has been running literally all day, so nothing should be cold on it now!
Posted : 29/11/2021 10:18 pm
Condensation drain frozen up?
Posted : 29/11/2021 10:27 pm
Condensate drain +1
Or the mid position valve. Take the actuator off the top and gently free the spindle by moving it with an adjustable spanner. Careful it only moves ~15deg each way.
Posted : 29/11/2021 10:32 pm
Get it serviced.
Posted : 29/11/2021 11:10 pm
Have you have switched the cold water valve off on the boiler elbow? If nothing is coming out of the tap that's what i would check first.
Second elbow from the right underneath the boiler.
Posted : 29/11/2021 11:50 pm
I repeat - get it serviced; there's no point fannying around with internet randoms who haven't seen or inspected the boiler and most of whom - if not all - are not qualified to comment.
If you take any of their advice, they have no liability or responsibility.
To end where I started - get it serviced.
Posted : 29/11/2021 11:57 pm
I repeat – get it serviced
It's serviced every year.
Reason for the post is to see if there was a simple solution before I ring the plumber and get the inevitable "I'm booked up for two weeks" comment.
Funny you should say that, my kitchen tap packed in today. The plastic splines on the tap handle snapped and now has mole grips on the tap spline, but nothing from any of the taps.
Don't think so, the pipe is inside the cupboard with the boiler and is warm as toast.
Posted : 30/11/2021 12:24 am
Have you have switched the cold water valve off on the boiler elbow? If nothing is coming out of the tap that’s what i would check first.
It appears that I had switched this off!
Now, this appears to have been the only way I re-pressurised the boiler this morning. On all the manuals for the boiler is shows a filling loop, but the loop has no taps to turn, so I'm now melting my brain trying to remember how i've filled this in the past.
To be fair the boiler has been an absolute PITA and has had about 5 expansion vessels, which are a known weak point on these. It's not cost me any money yet as it's been covered by boiler care.
Posted : 30/11/2021 12:50 am
Get a clear picture up of the pipes going into the boiler and any valves you can see.
Is the filing loop located somewhere else by any chance?
Posted : 30/11/2021 4:33 am
I have a 30cxi in my house. I have had to nurse it through a lot of issues.
Filling loop is the metal braided hose on the pipework entering the boiler. The taps are made of cheese so it is possible someone took them off and used a tool to open and close the valves.
Posted : 30/11/2021 7:27 am
There is an internal filling loop. For that boiler it needs a tube thingy that pushes up through a hole on the bottom of the boiler on to the filling valve. Can't remember what it's called, it will be in the manual. The hole (or opening) is on the rhs of the underside of the boiler.
Posted : 30/11/2021 1:01 pm
Not on a combi, surely?
Posted : 30/11/2021 1:27 pm
