classic asp help
[Closed] classic asp help
2 Users
Posting this here is a long shot but ...
I'm trying to add some function to a classic asp page written in vbscript
The main page is over 2000 lines of codes and also contains a load of 'includes' with many more lines of vbscript and javascript.
I cannot remove any code to make things simpler.
The page performs a search where, if the user does not select many filters for the data, we get a recordset of between 10,000 and 100,000 data rows.
The code I have added runs fine and does what it needs to do BUT, if it takes over (approximately) 90 seconds, nothing is ever sent back to the page.
I understand the default server timeout is 90 seconds (so the observed behaviour is suspicious) but this setting is overridden in IIS and set to 5 minutes, and the page doesn't actually throw a timeout error. It's as though the web browser (internet explorer) has just given up.
This is the first (and hopefully last) time I've used classic asp.
Any ideas?
Posted : 18/10/2016 1:25 pm
Database connection timing out after 90 seconds?
Posted : 18/10/2016 1:27 pm
Nope, it gets all the data and loops through it quite happily, writing the results to file.
Posted : 18/10/2016 1:30 pm
