Converting OS Explo...
[Closed] Converting OS Explorer Grid Refs to Landranger
10 Users
I've got a race on Saturday for which I've been provided OS Explorer grid references. This isn't much help, seeing as i only have a Landranger map of the area.
Is there any way of directly converting them? Also, is there any way of entering them into .gpx format for the GPS?
Posted : 02/09/2015 5:00 pm
It's the same grid 😕
Posted : 02/09/2015 5:01 pm
If you are asking these questions I sincerely hope you have someone you can follow!
There are a few websites which will let you plot a route on an OS map and download it as a GPX route.
Walkhighlands is one, you just need to register for free. Bikehike.co.uk is another.
Posted : 02/09/2015 5:09 pm
And make sure you have spare batteries for your GPS...
Posted : 02/09/2015 7:26 pm
Just add 37 to each set of three digits. You will be fine. 😉
Posted : 02/09/2015 7:30 pm
Oh you b**tard!!
Haha
Posted : 02/09/2015 8:27 pm
This might help - http://www.rambler-info.org.uk/osgrid.htm
Posted : 02/09/2015 8:30 pm
Surely, you just double each number?
Posted : 02/09/2015 8:34 pm
Only if you're using the tiberian conversion formula but then you've got to remember to only carry every third digit or you'll end up miles away.
Posted : 02/09/2015 8:38 pm
Don't forget to remove two from the second digit in each set, for every five years since the map was printed. 😆
Posted : 02/09/2015 8:39 pm
FFS, the magnetic deviation is at 2.736 degrees this year. Your adjustment would see you 312m off after 1km.
Posted : 02/09/2015 8:47 pm
Remember you already applied 'rule 37' and the Tiberian, as correcting factors.
Pfffft.
Amateur.
Posted : 02/09/2015 8:49 pm
Minor detail, so long as you remain roughly within the same 100km square
Posted : 02/09/2015 8:54 pm
Posted : 02/09/2015 8:56 pm
559 or 622? Neither maps work with modern wheels
Posted : 02/09/2015 9:13 pm
