Chin Up alternative...
[Closed] Chin Up alternatives
9 Users
There's quite a few fitness fans on here so I was wondering if anyone knew of any alternatives to chin ups? The reason being is my house is quite old and wouldn't be able to take the stress of a chin up bar in the door way. I have got a weights bench so I could probably try sitting behind the bench and doing seated chin ups, any other ideas?
Posted : 05/05/2011 10:28 am
You can buy chin bars that bolt to the wall - could put it outside or in the garage?
[url= http://www.ukfitnesssupplies.co.uk/productdetail.asp?ProductCatalogue=Powerbar-Mounted ]Like this...[/url]
I have found that nothing is as good as doing chin ups - certainly nothing hurts as much as them!
Posted : 05/05/2011 10:34 am
Make sure your architrave is screwed on tightly, and use your fingers on that 🙂
Posted : 05/05/2011 10:46 am
you could keep the bar loose and pull it down to your chin, this should achieve the same effect shouldn't it
Posted : 05/05/2011 11:27 am
I've got one of [url= http://www.boxfituk.com/training-equipment/multi-grip-wall-mounted-chinning-bar/prod_1133.html ]these[/url] up in my back passage (fnarr). Not cheap but very robust and wider grip than I can manage so should suit even the most munkey-armed fellows.
 grum
There's those climbers campus board thingys - you could screw one to an outside wall.
Posted : 05/05/2011 11:30 am
As long as you still show the pain and determination on your face, that it will have the same effect.
Posted : 05/05/2011 12:51 pm
Chin/dip station.
Posted : 05/05/2011 1:01 pm
Erm...
"cheer up"
"look up"
Posted : 05/05/2011 1:06 pm
