Chimney flue and ch...
[Closed] Chimney flue and chimney liner.......are these the same thing?
4 Users
 SiB
I'm pretty sure that they are??
Want to join the log burning stove chats so im now in a rush to get one fitted before Xmas!
Posted : 14/09/2013 9:32 am
flue - twin wall stainless steel flue for creating a "chimney" from nowt
flue liner - for lining an existing brick chimney
Posted : 14/09/2013 9:34 am
2 grades of steel used in flue liners, the cheaper one iis fine for burning logs, the more expensive one , and twin walled ss flues are for burning wood, peat, and coal.
Posted : 14/09/2013 11:22 am
Errr no to the above. I would not put a single skin type copex "flue" to use with a log burner.
As a standard definition the flue is the void within the chimney.
A liner then goes down this void to "line it", creating a flue liner. This helps with "older" chimneys as it is an assured method of removing gases safely.
Posted : 14/09/2013 11:42 am
