Hi Northwind - I may well take you up on your offer of some parts but will wait until I finish / get stuck before asking, just so I have the complete list. 🙂
2 reasons for the acrylic breakages.
The first is I chose to start building on a table too small to hold the printer. If I move anything then it knocks something else off the surface. That's how the first piece and the z axis screw broke. I am going to try and move it to a bigger work area.
The second was the wheel which was because I had tightened the bracket up and lined up the wheels correctly before discovering the metal frame bits were the wrong way around. I slide it off easily and rebuilt with the metal frame the right way round and slide the bracket back on. Unfortunately it was in a slightly different position and the right had vertical wasn't quite straight so as it slide down the acrylic was pushed apart a bit and the wheel snapped off.
The good news is that the super glue bonds appear to be sound so hopefully nothing lost.
A few questions you or others may be able to help with:
1)Can you re-print these parts or get them printed/laser cut in alloy and do the designs exist?
2)Is getting them redone in metal a bad idea, other than cost?
3)None of the wheels, pulleys, z screw etc are lubricated so far. Is this right and why not?
NOt managed to hurt yourself yet? Unusual for a WCA thread 😉
I looked at that too. Neat, but this is their second printer and I read some reviews of their first which put me off. Worth having a dig around.rjmccann101 - MemberI'm thinking about investing in one of these. Anyone know anything about them?
I can't see any reason not to get them done in metal but it seems overkill- once you're up and printing, parts are so simple to knock out if someone else has done a file for it (or design your own but I can't be arsed, for parts). Or in a pinch you can just hand cut and drill stuff out of whatever sheet material you like, though that seems to offend printer tinkerers.
The top Z axis mount is a classic for breaking though, it's just not strong enough in use, you want to put a spare corner support under it if you can, and then print a stronger one as soon as poss.
Basically there's nothing in the printer that relies on flex, it's only there for cheapness, and there's so much vibration and backlash in it at speed that beefing up anything is a good idea i think.
Lubrication and threadlock; I didn't bother in the first build except on the Z axis lead screw, which needs a light oil or it'll bind a bit. But I've added blue threadlock to pretty much everything as I go now and lubed obvious moving parts. But not surfaces, just pivots and rollers and such. Just for longevity rather than need, most of the rollers etc would be fine for years just rolling dry I think
I've just bought the Creality CR-10 from Gearbest so we'll see how we get on!
Slightly excited and slightly nervous of all the extra time spent at a computer!
AlexSimon - MemberI've just bought the Creality CR-10 from Gearbest so we'll see how we get on!
Thumbs up!!
I have been trying to wear my Wife down, regarding the 3-D printer purchase. Every time she says 'we could do with x, y, z' or 'that thingummy has broken' - my default response is 'if we had a 3-D printer, I could just whip up a new one/modify that/make that fit better'.
I suspect this tactic will end up with me living on a bench somewhere (I am not sure she could be arsed with a new patio), but it's good fun...
Exactly the same here stumpy01. I also keep playing the 'increases chance in job market for our sons' card.
I haven't told her that the first thing I'll be printing will be a cnc router yet 🙂
Not too much done today because of work but managed to get stuff taken apart and put back together the right way round.
I must learn up/down, front/back, left/right and notice that when parts aren't symmetrical there is probably a reason. On the bright side I am getting a good feel for how the printer goes together and how to move stuff.
I will YouTube more progress when I get time but here is the last photo of the day that sent me downstairs for a wine.
[url= https://farm5.staticflickr.com/4306/36003648701_9e236481c4_c.jp g" target="_blank">https://farm5.staticflickr.com/4306/36003648701_9e236481c4_c.jp g"/> [/img][/url][url= https://flic.kr/p/WRw7pP ]20170724_192410[/url] by [url= https://www.flickr.com/photos/89686376@N04/ ]WCA![/url], on Flickr
Yes, I have mounted the motor with the electric plug connector facing the floor. D'oh (again!)
I've always considered an electric screwdriver to be basically a dabbler's tool but now I have one, and a selection of allen key bits, sat permanently beside the printer, for exactly bullshit like that.
We are up and running!!!!
My first print was a 20x20x20 calibration cube that came out as 19.97x20.07x19.37 which I considered success. The Z was a little short because the filament feed was slipping I think.
I adjusted that by moving the pulley wheel a bit and this is my second print
A Z axis easy adjuster bracket. It works!
[url= https://farm5.staticflickr.com/4311/35405227954_e0a34349ec_k.jp g" target="_blank">https://farm5.staticflickr.com/4311/35405227954_e0a34349ec_k.jp g"/> [/img][/url][url= https://flic.kr/p/VWD3LJ ]20170729_124049[/url] by [url= https://www.flickr.com/photos/89686376@N04/ ]WCA![/url], on Flickr
What could possibly go wrong now?
Well....
The thing you are printing could start perfectly and then come unstuck from the bed
[url= https://farm5.staticflickr.com/4322/35452374563_e40e75c6fd_k.jp g" target="_blank">https://farm5.staticflickr.com/4322/35452374563_e40e75c6fd_k.jp g"/> [/img][/url][url= https://flic.kr/p/W1NFPi ]20170730_073759[/url] by [url= https://www.flickr.com/photos/89686376@N04/ ]WCA![/url], on Flickr
or you could leave the filament size at the default 3mm instead of the correct 1.75 mm and wait an hour to find this totality un-airtight fan shroud waiting for you
https://flic.kr/p/XeTXmg ][img] https://farm5.staticflickr.com/4315/36256873595_2359978db7_k.jp g" target="_blank">https://flic.kr/p/XeTXmg ][img] https://farm5.staticflickr.com/4315/36256873595_2359978db7_k.jp g"/> [/img][/url][url= https://flic.kr/p/XeTXmg ]20170730_073735[/url] by [url= https://www.flickr.com/photos/89686376@N04/ ]WCA![/url], on Flickr
Also, I think this suggests my bed isn't totally level. Left side nearest you is definately higher that the far right. Funnily enough those are bed level thumb screws I am printing 🙂
[url= https://farm5.staticflickr.com/4292/36089451902_ad5cda4430_k.jp g" target="_blank">https://farm5.staticflickr.com/4292/36089451902_ad5cda4430_k.jp g"/> [/img][/url][url= https://flic.kr/p/WZ6SHm ]20170730_074039[/url] by [url= https://www.flickr.com/photos/89686376@N04/ ]WCA![/url], on Flickr
Nice. Good start...
Impressed with the X/y dims on the cube.... Just need to sort the z.
Well done for getting this far!
I've joined a facebook group for the Creality CR-10 and there is a mix of problems and success stories. I'm hoping that problems are more likely to get posted 🙂
Lots of people talk about the bed sagging in the centre, so the 4 corners can be perfectly level, but they still suffer adhesion problems. Could that be happening to you?
I think the bed just wasn't quite level. Seems better after a bit of fiddling.
Now 2.5 hours into printing a small model boat. I know they said it would be slow...
91191 lines
32446.72mm of filament used in this print
The print goes:
- from 13.07 mm to 186.92 mm in X and is 173.85 mm wide
- from 38.25 mm to 161.75 mm in Y and is 123.51 mm deep
- from 0.00 mm to 35.60 mm in Z and is 35.60 mm high
Estimated duration: 118 layers, 3:02:42
Print started at: 13:02:44
WorldClassAccident - MemberPrint started at: 13:02:44
Is it still going? Did it work? Any pics?
The big print for the paddle boat hull was fine, as were the two pegs that pushed into that piece.
[url= https://farm5.staticflickr.com/4311/35482930713_080e4832b0_c.jp g" target="_blank">https://farm5.staticflickr.com/4311/35482930713_080e4832b0_c.jp g"/> [/img][/url][url= https://flic.kr/p/W4vi6t ]20170731_152836[/url] by [url= https://www.flickr.com/photos/89686376@N04/ ]WCA![/url], on Flickr
I then started on the paddle and left it printing.
I returned a while later and it had stopped printing without completing the paddle but with the hotend positioned nicely to the side of the bed but covered in a smooth molten plastic shell.
This shows some of the plastic I haven't managed to chip/scrape off. It also shows the thermistor that is now plastic-welded into position and not working. 🙁
[url= https://farm5.staticflickr.com/4299/36287206135_37b936ffa7_c.jp g" target="_blank">https://farm5.staticflickr.com/4299/36287206135_37b936ffa7_c.jp g"/> [/img][/url][url= https://flic.kr/p/Xhzqa6 ]20170731_151943[/url] by [url= https://www.flickr.com/photos/89686376@N04/ ]WCA![/url], on Flickr
Replacement thermistors are easy to find but any ideas on where to get a new hotend that will fit?
[url= https://farm5.staticflickr.com/4320/35482899583_fa0d7974f2_c.jp g" target="_blank">https://farm5.staticflickr.com/4320/35482899583_fa0d7974f2_c.jp g"/> [/img][/url][url= https://flic.kr/p/W4v8QK ]20170731_151959[/url] by [url= https://www.flickr.com/photos/89686376@N04/ ]WCA![/url], on Flickr
Shame - that hull print looks pretty good!
Best way to clean this up?
[url= https://farm5.staticflickr.com/4314/35483496733_8d78d69dfe_c.jp g" target="_blank">https://farm5.staticflickr.com/4314/35483496733_8d78d69dfe_c.jp g"/> [/img][/url][url= https://flic.kr/p/W4ycmr ]20170731_160417[/url] by [url= https://www.flickr.com/photos/89686376@N04/ ]WCA![/url], on Flickr
Can't heat it on the printer as the thermistor is knackered.
Blowtorch perhaps?
What plastic is it? ABS or PLA?
You could probably dip it in acetone and leave for a while...
PLA so acetone won't work but enough heat should unless you can suggest better
Nice to see you are up and running, despite having some problems. Welcome to the world of waiting hours to find it's failed! 😉
Stick it in the oven? Set to about 140°C, it should peel off. I had to do a similar thing to remove my nozzle. 😯
This link may help you to work out what is wrong, or how to improve your prints. [url= https://www.simplify3d.com/support/print-quality-troubleshooting/ ]Print Quality Troubleshooting[/url]
[url= http://www.3dbenchy.com/ ]The 3D Benchy test print[/url] is pretty good, it really gives you an idea of what you can and cannot print and then you can fine tune your settings. In the near future you may find you have different settings, one that's really good at overhangs/gaps and another setting that's really good at all the other stuff.
What are you using on your bed? I have really good success with blue painters tape and that is without a hot bed.
A very thin diamond file in a dremel cleaned out the hole for the thermistor with no fire required.
I have a piece of glass from a cheap clip frame clipped to the standard bed and then strips of cheap paper masking tape over than. Clip frame was £2 and the masking tape was 50p. Seem to work fine.
Still playing around to see what I can do.
I will probably try to do the boat paddle in ABS as I have a test roll. That will also test the heated bed (I think).
I'm thinking about getting one of these printers, what software (free) is best for designing things?
I've downloaded Autodesk Fusion360 (free for hobbiests and students apparently).
Lovely program. Doesn't seem any harder to learn than Sketchup to be honest.
Sketchup is the other obvious answer.
Lots of the things on Thiniverse come with Fusion files and you can click 'play' on the timeline to see how they were made. Very cool.
I use FreeCAD for designing and Cura for slicing as I use an ultimaker and it does 90% of the thinking for me.
Tempted to try Fusion360 as FreeCad is giving me a headache this morning trying to 'stamp' the company logo onto a box grrrrrr.
Cheers Alex/thisisnotaspoon
Looks like Freecad then as my OS is Linux, and Fusion/Sketchup are for Windows or Mac!
Fusion 360 for the browser was on trial for a while and is now in 'preview' whatever that means (alpha/beta?).
You have to apply to be able to use it.
Also look at solvespace. On Windows and Linux. Not as many bells and whistles as freecad but stability is better.
There's also https://www.tinkercad.com/ from Autodesk which is browser-based, but I've never tried it.
Thisisnotaspoon, there's a setting in Freecad (edit/preferences, document tab) that you can uncheck [b]'Add the program logo to the generated thumbnail'[/b], have you tried that?
Well my Creality CR-10 turned up yesterday.
Easy build as expected (about 30mins taking it very slow).
Started to print the included test file. Looked absolutely perfect straight onto the glass until the nozzle temp suddenly dropped and it stopped extruding 🙁
Replacement heater cartridge ordered (£2.99) and we'll try again. Not sure I trust my soldering.
[img]
?oh=0b7e5d44abcaf6cf8c2a164b9025380e&oe=59F45347[/img]
Blimey, it looks big!
Shame it's failed though!
I'm trying to forget all about 3-D printers at the mo, having realised I don't have the spare cash to spank on a 'toy' and I don't really have the time to div around with it, even if I did get one. Hmph.
It's not quite as big as it looks in that pic. It's an awkward thing to store though. Haven't really worked out where it's going to live!
I've just got a MarkForged Mark Two. Prints carbon infused stuff. AWESOME.
Get out of here with yer warrantied, supported, well built product 🙂timnoyce - MemberI've just got a MarkForged Mark Two. Prints carbon infused stuff. AWESOME.
Just caught up with this thread, interesting read. Mildly relieved that WCA hasn't glue-gunned himself to the desk. (-:
I was idly wondering, what's the running cost of these things? I've a few friends who "cosplay" (fancy dress at cons rather than some kinky fetish) and I thought maybe a 3D printer could be handy for printing accessories like weapons and the like. Probably a non-starter if it's going to cost the GDP of a small African country to print anything larger than a Polo mint.
Cougar - ModeratorI was idly wondering, what's the running cost of these things? I've a few friends who "cosplay" (fancy dress at cons rather than some kinky fetish) and I thought maybe a 3D printer could be handy for printing accessories like weapons and the like. Probably a non-starter if it's going to cost the GDP of a small African country to print anything larger than a Polo mint.
Electricity aside, it's basically all about weight- if you're buying in hobbyist quantities you're generally spending somewhere between £10 and £20 per kilo for most filaments. You get a bit of wastage from support materials- depends a lot on the design, most of the stuff I print is very efficient, some cosmetic stuff not so much (frinstance a cosplay helmet might be one humungous piece with a load of supports, or it might be 4 or 5 bits that you assemble after printing, with less supports) Also you would vary the density of printing for strength.
So it depends but imagining how much a part would weigh if it was made of standard lego bricks is a good place to start.
Thisisnotaspoon, there's a setting in Freecad (edit/preferences, document tab) that you can uncheck 'Add the program logo to the generated thumbnail', have you tried that?
Maybe I didn't describe it very well, I have a 3D file of the company logo extruded 1mm, which normally I manage to put onto stuff we print (because stuff like that impresses the boss more than a well-designed part!) and do a boolean operation to 'stamp' (engrave?) it out of the surface.
Sorted it out in the end, setting the angle to 120deg and each axis to 1.0 somehow results in rotating it by 90deg in two axis. I'm sure if I remembered trig better I could explain why that happens.......
Electricity aside, it's basically all about weight- if you're buying in hobbyist quantities you're generally spending somewhere between £10 and £20 per kilo for most filaments. You get a bit of wastage from support materials- depends a lot on the design, most of the stuff I print is very efficient, some cosmetic stuff not so much (frinstance a cosplay helmet might be one humungous piece with a load of supports, or it might be 4 or 5 bits that you assemble after printing, with less supports) Also you would vary the density of printing for strength.So it depends but imagining how much a part would weigh if it was made of standard lego bricks is a good place to start.
Your real issue will be boredom though. To print out a matchbox sized object with ~2mm walls takes about 2 hours on medium settings. You can run them much faster (XY axis) and with lower resolutions (z) to speed things up, but quality drops off.
Where 3D printing would work well, is small intricate things. So for a sword, start off with one from a toy shop and 3D print a new handle. Or make the blade by another method (plane a bit of wood down?). It's too slow to work effectively on large parts, and the odds of a failed print increases the larger the print.
Sounds reasonable.
Sounds expensive. Where are you sourcing Lego from at ten quid a kilo?
Time is a factor. 3d printers are *slow* and I'm not willing to leave mine on, unattended overnight - lots of people do but I'm not going there.
Lots of big prints can be split down into constituent parts but I see some people going for 70 hour prints 😯
Sounds reasonable.
Especially when you consider a kilo is probably 100+ hours of printing!
I bought a 2.2kg drum yesterday for £50*, I expect never to finish it! I also need to rig up a new holder for it as it's too big for the ultimaker!
*you can get really cheap, £6/750g spools from ebay and amazon, but as mines for work it only takes one 1 hour print to fail and the savings wiped out.
Cougar - Moderator
How much it weighs not how much it costs! But I think you know that 😆
It does depend a lot on how dense you print- a lot of what I do is very solid, for strength and crush resistance. But a cosplay piece usually isn't going to be like that, you'd want it to be durable but not bombproof. So you can set the infill low and have solid outsides but print the inside in a honeycomb or similiar, to save weight (and therefore plastic). Not to mention time.
TINAS is spot on, time is a big deal, for actual industrial printing or for anyone doing it full time it's a real cost (for me, it's not, my printer doesn't run constantly so it's an unspent resource). And that's where having your printer really dialed and reliable comes into its own, too- I can put on a 10 hour job and be pretty confident that if it's printing OK after 10 minutes, it'll produce something decent. But if it's less reliable, there's a pretty good chance you come back and you've printed a massive blob- wasted a load of filament but also time and maybe created yourself printer issues too.
(they say never leave it unattended but I doubt anyone actually follows that advice; I have an old smartphone running as a webcam so I can keep an eye on mine for safety but I very rarely run it overnight (and the room I have it in is pretty fire safe anyway) It's a low risk but, high enough to think about
And you've got to consider mean times to failure too- being able to run for an hour reliably is fine for a lot of the parts I print but if you've got a big job to do, you need a different level of reliability
Got mine working my fiddling with some wires (Creality support wasn't quite as bad as I expected).
Printed a strain relief for one of the wires which people recommend and then went onto a [url= http://3dbenchy.com/ ]3D Benchy[/url] and calibration cube.
All came out much better than I expected:
[img]
?oh=f9b93dd75d6cb3e986307cfa6b4c2f62&oe=5A36EF50[/img]
[img]
?oh=18be6183a948dd413561801be61c7237&oe=59F8B0A2[/img]
Very pleased. Time to start printing some of my own creations!
I didn't, I just misread what he was saying.
Ah, cunning. I hadn't thought of that, ta.
Presumably for bigger pieces you can make them in modules, like quarters or something, and stitch together? (And that's probably preferable because of possible failure.) Like, if I wanted to make a sub-machine gun prop, I could do it in quarters or something.
That's a pretty good benchy! Here's my first:
@Cougar- yep, also means you can make things bigger than your printer too. Design and slicer software can cut up parts pretty easily too so you can make your own splits. And if you print in ABS, you can stick it all together with just a little acetone.
AlexSimon, I just googled the CR-10 and it looks immense. I've got access to an Objet30 and now the Markforged, the resolution is excellent but the build size is limited to around 300x120x150 on both. The CR-10 looks amazing for the money. Totally interested in something like that for home use now!
Looking forward to seeing some more of your prints 😀
Really pleased with how everything is coming out.
That heater cartridge failed again today, but pliers sorted it and they are sending me a new hot end (who knows how long it'll take to arrive). I ordered a cheap cartridge of ebay in the meantime, but I think I'll just make do (don't trust my soldering or want to mess with it too much).
Anyway - printed a few bits and bobs - all look great. Vase mode is particularly impressive.
This is the latest.
It's the [url= https://www.thingiverse.com/thing:2238443 ]springy turtle[/url] off the Thingiverse home page.
Need some more matt PLA and some different colours. Getting bored of orange and white!
In the meantime, we've been learning Fusion 360 and have been designing our own things.
Really enjoying it, although it's always difficult when you start a project and think "ok - how do I start this shape then".
For example, I wouldn't know where to start with that turtle shell.
Do any of you print while you are out the house? I have a 24 hour print to do (50m of 3mm filament) but I'm not too sure about printing when I'm out the house, it hasn't screwed up yet while printing.. I do use OctoPi withe PiCam to keep an eye on the prints when I'm around the house.
The best bit of advice I was given when learning CAD was there is no wrong or right way of drawing, but there maybe a quicker way.
If I had a professional machine I would probably do it, but not with these Chinese kits. Same as charging Chinese batteries for lights 🙂Do any of you print while you are out the house?
And that's just my shed. Even less likely in the house.
Well after wondering what we were going to print, I have to say that the printer has been running about 8 hours a day whenever we're at home!
Completely sparked my boys' imagination and they are loving Fusion 360 (as am I).
Currently printing loads of bits to make a Nintendo Switch car mount which my eldest designed.
I've been sticking to mostly graphical pieces like these two signs for local clubs I'm involved with.
[url= http://thingswelike.org/reserved-signs.jp g" target="_blank">
http://thingswelike.org/reserved-signs.jp g"/> [/img][/url]
The green and white one involved a nerve-wracking filament change at the right layer!
Wow! Missed your turtle update....looks great, as do those two signs!
What is going wrong with the heater cartridge, then? Failing to heat, I guess?
Where do you source a replacement from? Are they standard or do you need the cartridge from the printer manufacturer?
It's just a poor crimp on the connection I think. I can get it working by squeezing with pliers, but it fails every-so-often.
I have a replacement heater here (cost £1.99and are a generic item), but I don't fancy soldering and messing. The whole hot end assembly is £24.
Gearbest have been worse than useless. Creality were helpful with advice, but said I had to go through Gearbest.
I'll probably suck it up and buy the £24 option.
Looks really cool, but I don't think my budget and space will stretch to the CR10. What are peoples thoughts experiences with an Anet A8?
AlexSimon, ta for the explanation.
SammyC - Member
Plenty of reviews on YouTube. It seems to be quite a capable machine.
The A8 is all about the mods. Out of the box it's average - once you print your own modifications and tweak it, it can be great.
If I was buying now, I'd be tempted by the Creality Ender-2 (also rebranded HICTOP). Currently about £135 with codes.
Small print volume, but many shared parts with the CR-10.
[url= https://www.3dprintersonlinestore.com/creality-ender2-mini-kit ]Link to the Ender-2[/url]
Interesting! It gets very good reviews
I haven't actually printed anything beyond that print volume either.
I do have something in the works, but to be honest I could do it in sections without too much bother.
On the CR-10 forums it seems dominated by cosplay costume makers and modellers who like to print massive anime figures and fill/paint them.
Apart from the fact that obviously [i]everyone[/i] would like [url= https://www.thingiverse.com/thing:1779274 ]an IronMan suit[/url], I don't seem to be it's target market. Mainly because I'm too impatient to wait days for the big prints to finish 🙂
(Basically I should have bought the Ender-2 🙂 )
Apart from the fact that obviously everyone would like an IronMan suit,
Mate of mine's making one of those. Using foam rather than plastic though.
I think that's what holds me back is the what would I use it for question. But I could use it for work in many situations and my boys would love playing with it.
I have been following this thread with interest and that Ender 2 is really tempting.
I also have no idea what I would make with it, but still want one.
I was worried about what to print too (as you can read earlier in the thread), but now that it's here, ideas come from everywhere.
But then I am a designer by trade.
AlexSimon - Member
I've had a look at the Ender-2 and it does seem to get good reviews.
I can't help but think that the cantilever nature of the design won't give as good results - particularly as things start to wear.
This might be of interest. Adam Savage with one of those 3D-printed mega-scale Curta
Amazing finish on that. I wonder if it's just an amazing printer, or if it's post-processed.
Unfortunately this isn't an amazing post with photo's of what I've printed. 😐
I have found a [url= https://www.hotukdeals.com/deals/anet-a8-desktop-3d-printer-eu-plug-for-9169-using-code-gearbest-2814167 ]super cheap 3D printer[/url], under £100 and print volume is 220x220x240mm 😯
EDIT:
I did design a [url= https://www.thingiverse.com/thing:2336437 ]Evil Wreckoning Clip Holder[/url]. This needs an update as over time it becomes loose.
I designed a [url= https://www.thingiverse.com/thing:2370670 ]replacement top cup holder ring[/url] for the Sakura cup holder, it now holds a proper cup of coffee (Costa/Starbucks), this is fitted in my car as it only came with one cup holder.
The Anet A8 is very well known.
I put some comments in the end of that thread.
Basically, only buy it if you have plenty of time and patience, but once modded it can be safe and high quality.
If you value your time more than your cash - buy something better.
Go away and think about what you've done.
I looked briefly into getting a 3d printer at home, but talked myself out of it as I really don't have much to make or any time to play with it.
Instead I've used these guys a few times and find them to be very good.
https://www.3dprint-uk.co.uk
You send them an STL file of all the parts you want and they arrive about 2 weeks later.
They only use SLS (nylon) which is the process used by most engineering/design companies for working prototypes. The parts are very durable and stable over time.
I used to work for Dyson and SLS is used for almost everything, the machines cost big money.
The price is just set by the external dimensions, so you can position parts in such a way that gets best value for money. Anything hollow can be filled with bits which are effectivity free.
As clones of the Creality CR-10 go, this looks pretty good!
£259 with the code from the video seems good value.
I've just started my next big project.
A CNC Router made from a lot of 3d printed parts.
[url= https://cdn.thingiverse.com/renders/92/79/e0/06/de/8cf4ae8a1dc4a987229f62db85e7121c_preview_featured.jp g" target="_blank">https://cdn.thingiverse.com/renders/92/79/e0/06/de/8cf4ae8a1dc4a987229f62db85e7121c_preview_featured.jp g"/> [/img][/url]
https://www.thingiverse.com/thing:1750276
At first I thought I could build one for about £300, but the models that come in at this price (MPCNC and a couple of others) look a little flimsy for purely routing ply and aluminium, so I've gone for this one instead.
My Bill of Materials currently sits at £440 including PLA and everything. Slightly concerned that it's an awful lot of money to spend on something that also requires a lot of time and skill to get working, but I'm sure my son (and YouTube) will come to the rescue!
Most of the bits are currently on their way on a slow boat from China.
Hoping to do the bulk of the work over the Christmas break.
Time to get printing!
Decided to print the blue bits in the image above in PETG so that it's heat resistant and stronger, but having an absolute mare trying to get it to stay stuck to the bed during the long (12+ hour prints).
Glass on 70-degree bed and slow printing = Nope
Glass on 80-degree bed and slow printing = Nope
Pritt stick on 80-degree bed and slow printing = Nope
Hairspray stick on 80-degree bed and slow printing = Nope
Blue masking tape on 80-degree bed and slow printing = Best so far, but it's still starting to warp at 4 hours 🙁
I've heard PETG doesn't like to be as squashed into the bed as much as PLA, but my attempts to do that resulted in hardly any sticking at all (even the brim came off before completing).
Any tips?
I'd suggest giving ColorFabb XT a go. I bought some, not knowing it was similar to PETG, until yesterday when I went to re-order another roll. I find it sticks to the bed just fine, it's actually hard to get off the blue tape, I don't use a heated bed. Recently printed a part that was 250x80 by 60mm high and it didn't warp or lift.
I do print the first layer at 50% speed and about 10°C hotter than the rest of the print and no cooling until about layer 3, it also in an enclosure. Have a look at Simplify 3D, it is worth the cost, as has a lot of cool features such as custom settings for first layer and loads more things.
PETG can also take chunks out of your glass bed when you remove the finished item 😯
That would at least mean that I'd got to the end of a print! 🙂allthepies - MemberPETG can also take chunks out of your glass bed when you remove the finished item
Interesting. I can't really afford ColorFabb XT (need 2.5kg for this project), but then buy cheap buy twice!Milkie - MemberI'd suggest giving ColorFabb XT a go. I bought some, not knowing it was similar to PETG, until yesterday when I went to re-order another roll. I find it sticks to the bed just fine, it's actually hard to get off the blue tape, I don't use a heated bed. Recently printed a part that was 250x80 by 60mm high and it didn't warp or lift.
That is exactly what I have found. I don't buy cheap stuff anymore, gone through many reels of cheap stuff and just ended up chasing the settings, printing more than once and ruining a nozzle. 2.5Kg though 😯 How big is the part?
All those blue bits on the image above (the CNC router). It requires 50% infill.
I understand the act of making it is fun in itself but in this case wouldn't you be better off buying something? For example this is almost exactly the same as your bill of materials: https://www.ebay.co.uk/itm/300W-3040-New-3-Axis-CNC-Router-Engraver-3D-Engraving-Drilling-Milling-Machine/263151299677 but all aluminium and already working.
That's pretty much the machine I started on. Very sturdy construction and worked well until I sold it on for about half what I paid for it and bought/built a much bigger one.
No help with the question about printing with PETG.
No help with anything else really, as I don't yet have a 3-D printer.
But, I've just been told that we are going to get a bonus this small Christmas bonus this year, because things are finally looking up in the industry I work in & the company is making good progress.
Anyway - I am planning on splitting it 50/50 with my Wife, but this will still hopefully leave me with enough to get a budget 3-D printer.
Excited already & I'm still not really sure if a) I'll get enough of a bonus to afford it, or b) what printer I would be able to get.
I like the idea of the CR-10, but not sure I need that much build volume.
Tevo Tarantula looks like a good performing printer for the price.
But, now the Anycubic i3 mega has popped onto my radar & also looks like a good bet!
I'll get Christmas out of the way first & then worry about it!!
AlexSimon, good luck with the 3-D printed CNC router and getting your parts printed!
Blimey - doing a quick search....has anyone bought anything from lightinthebox.com?
They've got the:
- Tevo Tarantula for £117
- Tevo Tornado (rip-off CR10) for £234
- Anycubic i3 Mega for £220!!
Even the Tevo Tarantula with dual extruders is only £173.....
