Changing headlight ...
[Closed] Changing headlight bulbs on a Berlingo - how hard?
5 Users
 grum
I read you might need to take off the bumper/grill to get at the housing etc. Never tried before - anyone done it?
Or should I just take it to a garage? I've downloaded the service manual from the Berlingo forum but I can't read it properly for some reason.
It's a 53 plate BTW.
Posted : 22/05/2015 4:19 pm
Can't be that hard. Just have a go...
Posted : 22/05/2015 4:33 pm
 grum
Cheers - just realised from looking at the service manual that it's probably not just a bulb that's gone? It looks like it's the same bulb for dipped/full beam AFAICT.
The headlights work fine full beam but there's nothing at all when dipped. I assumed they were different bulbs.
As you can see I'm not very knowledgable about such things but generally willing to have a go!
Posted : 22/05/2015 4:54 pm
Is it an H4 bulb? Twin element bulb. One usually fails before the other, completely normal. Have a go, it'll help if you have small hands and leathery skin, and a penchant for crypton factor style dexterity puzzles. Good luck...
Posted : 22/05/2015 4:59 pm
Local Halfords? They'll fit them for a couple of quid - probably worth it to avoid the knuckle rash if you're not sure what you're doing.
Posted : 22/05/2015 5:01 pm
Its no bother but a bit fiddly. Dont touch the new bulb.
Posted : 22/05/2015 5:22 pm
Almost always a fiddly and a pain to do but usually procedure is
Remove electrical plug from bulb
some sort of clip holds the bulb in situ [ and possibly plug above]
Remove it
Remove the bulb
It will havs some sort of tag so it only fits in one way - s o light points correctly
Reinstall
Fiddly but not hard assuming you can reach easily
Posted : 22/05/2015 5:26 pm
 grum
Thanks all.
Got Halfords man to do it this time but reckon I would do it myself mext time after watching him. The passenger side one was quite fiddly due to where the fuse box/wiring is which i think is why people were talking about taking off the bumper and pulling the housing out to make more room. He managed ok without though.
Posted : 22/05/2015 7:04 pm
