Changed from BT to ...
[Closed] Changed from BT to Plusnet and connection is faster and more stable. How?
9 Users
Just changed over to Plusnet from BT.
Had to swop the router as the BT Home Hub is "locked" to BT, however, the Plusnet one is identical, just a different case.
My connection is now faster and more stable, I regularly used to get hangs on Netflix and iPlayer, now it seems a lot better.
How can this be? Basically the same provider with the same router on the same telephone line. Seems very strange.
Half the price as well.
Posted : 06/10/2016 9:28 am
Hmmm. I'd be interested in thoughts on this too, because I keep thinking about swapping from Talk Talk but am not going to stump up for fibre, so assumed the speed/reliability would remain the same as it's the same bit of wire coming into the house....
Posted : 06/10/2016 9:33 am
It isn't. A quick googlage and the instructions are simple.
Posted : 06/10/2016 9:34 am
Same router firmware?
While with BT, something triggered a lower speed profile which stayed, until line reset with the change to Plusnet?
Hope you remembered https://www.topcashback.co.uk/plusnet_broadband/ 😆
My speed and stability has dropped after moving from PlusNet to Sky. 🙁
Thankfully after cashback and vouchers, Sky only cost £20 for the year and I am not locked in past a year.
I do not think the Sky router helps - but I cannot use my own router with Sky, bandits.
Posted : 06/10/2016 9:36 am
Less contention is my guess.
Why bother? Just unplugged the BT one and replaced it with the Plusnet. Didn't even need to swap the power supply.
Posted : 06/10/2016 9:37 am
2 likely explanations - contention (how many people you are sharing the line with), and traffic shaping, which is where internet service providers restrict certain kinds of traffic e.g. online gaming / video streaming
Posted : 06/10/2016 9:51 am
you will likely be on a different router in the local exchange (plusnet's, rather than BT's), and again further upstream.
Historically (prior to the BT acquisition) Plusnet were quite a solid ISP and invested a fair bit in bandwidth and infrastructure. Don't know how it is now but at the time it allowed them to offer better connections etc.
Posted : 06/10/2016 9:59 am
I experienced exactly the same, I just concluded Plusnet have more hamsters spinning more wheels.
Posted : 06/10/2016 10:07 am
franksinatra - Member
Sounds most plausible.......wanders of in search of a comparison website...
Ta.
Posted : 06/10/2016 10:12 am
