Central heating ......
[Closed] Central heating ........
4 Users
Which is more affective/efficient .....Constant with thermostat ......or timed Blasting away for x amount of hours until warm ...
What do you do ...?
Posted : 23/11/2014 11:57 am
Heating the space when you need the heat is more efficient I believe.
Posted : 23/11/2014 12:00 pm
I'm in the basement flat of a big Victorian house and it's def warmer if I've kept the thermostat on 16 degrees when I'm out and then stick it up to 20 when I come home. Leaving the place cold means it never gets fully warm even after a couple of hours at 20 degrees.
Depends on the volume of air you need to heat and how well insulated the house is, I guess
Posted : 23/11/2014 12:18 pm
Brooess final sentence has it.
Uber insulated and airtight= on constantly.
For everyone else, turn it on and off.
Posted : 23/11/2014 1:11 pm
