Hi guys, I've dug out some rotten concrete and I intend to fill it with new. the hole I have equates to approx 0.1 meter^3 (if my calculations are right).
Roughly how much dry cement and aggregate will I need to create enough to fill above hole?
thanks in advance
Typical density of concrete is about 2400 kg/m^3 - so you'll need 1/10th of this for your 0.1 m^3 hole. Very rough mix quantities will be 1 part cement, 2 parts sand and 4 parts coarse aggregate - so if you're buying bagged ingredients from a DIY store then 2 bags of cement, 2 bags of sand and 4 bags of gravel should be about right (assuming 25 kg bags of cement and 40 kg bags of sand and gravel).
Depends on how strong you need the mix tbh. I would allow 8 x 25kg bags of ballast and 32(ish)kg cement. A single bag of cement may just be enough but really depends on the strength you need.
So what are the measurements???
0.1m cubed? That is one litre. Density has nothing to do with the volume required.
1.3(w) x 1.8(l) x 0.04(d) = 0.094m^3??
doesn't need to be too strong, it's an internal floor that will be covered with either laminate or carpet and underlay.
Being only 40mm deep I might be tempted to go with a deep fill self leveling compound or one mix (all 25 kg bags 1 cement, 2 sand 4 aggregate) and then top it up with a self leveling compound
will sharp sand be an adequate aggregate or should I use something more coarse?
40mm deep should only require a sand / cement screed i.e. no aggregate.
7 or 8 25kg bags of coarse sand and a couple of bags of cement. Could be left slightly low (about 3 - 5mm) and finished with self levelling as carlos said.
Edit - if you want to add aggregate for strength use a 10mm or grano dust.
