CBT motorbike thing
[Closed] CBT motorbike thing
16 Users
I did mine on Friday and wondered if other mountain bikers, new to motorbikes and doing their CBT struggled with a brake lever actually being the clutch.
I found it fine when I had time to really think about what I was doing but as soon as I was out on the road my brain thought it was a brake lever.
Posted : 24/08/2016 7:50 am
A little. You do adjust quickly, and I'm very thankful we run cycle brakes as right-front (unlike almost everywhere else) so at least that's consistent.
Posted : 24/08/2016 7:53 am
I was actually quite surprised that it took me no time to adapt at all. I was worried about it before I started with motorbikes. But as mentioned above, I was very thankful that the front brake is consistent. The LBS once cabled my brakes Euro style without telling me. I made it about 3 meters down the road before crashing.
Posted : 24/08/2016 8:03 am
Personally no but then I've raced bikes since I was 8.
Oddly for me I run my BSO's euro after otb one time too many as a kid.
Posted : 24/08/2016 8:06 am
 nerd
I did mine on a scooter with a CVT*, so the brakes were in the same position.
*I only wanted something easy to ride to work and modern Vespas are still pretty cool.
Posted : 24/08/2016 8:13 am
Surprisingly no, I'd never sat on a bike before, aside from being a pillion a few times. I was chatting about it to the instructor before we started and I assumed I'd be okay on the whole balancing around the cones bit, but would struggle with the brakes, gears etc - in actual fact, and even more so when I moved onto the ironclad 500s we did our lessons on it felt so dissimilar to MTB that it wasn't a problem. There was little cross over in terms of 'operating' them for me.
Where being a cyclist helped me was self-preservation instinct on the road and where being a MTBer really helped was avoiding that whole panic braking, going stiff thing when something goes slightly wrong - that's what knocks off 90% of people who fall during their CBT, it's not hitting something, there's noting to hit, it's panic braking or worse panic throttle!
Posted : 24/08/2016 8:29 am
As P-Jay said, there's so little crossover between riding a 200kg CB500 with 60hp and a 7kg push bike with 1/8th hp that it's not something I ever really worried about.
By the same logic, I never tried to pedal with the gear lever either.
Posted : 24/08/2016 8:59 am
I see what your'e getting at but to me all bikes feel largely the same and I make no distinctions between any of them
Posted : 24/08/2016 9:12 am
It was going round corners that I struggled with. It was fine slowly around cones but coming up to a bend at 40mph I leaned and the bike kept going straight!!!! On a motorbike you lean the bike and you follow, its the other way round on a bicycle!!
Posted : 24/08/2016 10:27 am
try out your new found 'motorbike' skill on the MTB...
Posted : 24/08/2016 10:37 am
A_a - Google 'counter steering' on a motorcycle. That's how you're going round corners, not by leaning. You'll be doing it to some extent even if you don't realise it. I've tried to get round a corner no handed on a motorbike like I can on a bicycle but it's impossible. You'll only get about 10% of your cornering from leaning I reckon, the rest from counter steering. Once your aware of it, give it a go. But GENTLY!
Basically, you push on the left side of the bars to turn left, effectively steering very slightly in the opposite direction to the turn. 🙂
Posted : 24/08/2016 10:57 am
Countersteering - trust me you do it on anything with a spinning wheel or you can't turn it!
Thank gyroscopic forces.
I know about counter steering thanks. You cant go round a corner on 2 wheels without it. Countersteering drops the bike in but it will stand back up again and straighten if you dont lean. On a motorbike you lean the bike on a bicycle it will follow you. Depends on which is heavier.
Posted : 24/08/2016 12:26 pm
Pushing the bike about is pretty normal on mtb. I was just taken by suprise tootling along on a motorbike for the first time.
Obviously I am not riding god enough for stw!!
Posted : 24/08/2016 12:29 pm
Never been an issue. I can't figure out how Americans can go from motorbike to bicycle though with the front brake on yhe wrong side of the bicycle.
Posted : 24/08/2016 1:16 pm
On second thoughts lets not be mean!!
Posted : 24/08/2016 1:20 pm
my bikes, all of them, have always had their brakes set up USA style, maybe it explains my difficulties from when I first posted the question. 😉
Posted : 24/08/2016 2:27 pm
I don't know all the technical terms in regards to riding bicycles or motorbikes - I just do what I do and it all seems to work.
Perhaps it's down to style and or how natural/technical minded you are, but for me the biggest difference was the fact that on a motorbike the bike weighs more than you and it changes the feel of it, not the same as being in a car, far from, but it certainly different to riding a bicycle which weighs less than you.
Posted : 24/08/2016 3:02 pm
The first time something jumps out infront of you could be spectacular. You need a go-pro... 😀
Posted : 24/08/2016 3:14 pm
I think I've done it once in 6 years of riding, but that was a proper emergency stop situation so I was anchored up hard on the front anyway, so it had the happy advantage of not stalling at the end of it...
Posted : 24/08/2016 3:36 pm
This counter steering thing has blown my mind! I give it a whirl yesterday on my commuter bicycle.. About 10 mph tried to turn the bars left and off I piss to the right! Been riding bicycles for 25 years since I was a lad and guess it must just be a natural thing??
I've watched about 5 videos on this as it applies to motorbikes as I'm currently saving up to get some rider training and get through my test. I take it this will be covered in detail by the instructor?
Posted : 31/08/2016 8:27 pm
I doubt it. It still works though.
Posted : 31/08/2016 8:30 pm
Unless the training has changed, counter steering isn't taught at CBT or direct access
It was covered in detail when I did my IAM, when you read up on (or do) any track riding stuff, and when I saw Jedi
It's illogical when you first learn about it, but it's fine once you get it
Posted : 01/09/2016 9:47 am
CBT covered countersteering when I did it, although it was some 8 or so years ago.
Never had a problem transitioning between motorbike and mountain bike - didn't need any tips or anything, it's just they are very different! Bit more commonality when it came to cornering on the fatbike but nothing to get excited about.
Posted : 01/09/2016 10:53 am
