Cat 7 cable?
[Closed] Cat 7 cable?
11 Users
We are getting 200Mbps BT Infinity installed next week.
Modem will be in the hall, router will be in cupboard under stairs so I was planning on running cat 6 cable between the two, as cat 5 wouldn't be quick enough.
We've got a spark in at the moment so I asked him to run a cat 6 from the hall to the cupboard while he had the floor up, and leave it for me to terminate (he said he'd rather not terminate it anyway).
I've bought cat 6 face plates and patch cables, but he's just phoned to say he can only get cat 7 cable.
He said he'd leave a draw wire there too incase I want to run a cat 6 instead, but will I just be able to terminate the cat 7 into the cat 6 IDC terms?
Is the colour code etc. still the same?
Posted : 19/03/2015 10:24 am
 ton
colour code is same. very hard to work with, riggers don't use it, no benefit over cat 6.
Posted : 19/03/2015 10:28 am
cat 5 isn't fast enough over a sum 10 meter run? how did you come to that conclusion? are you running 10Gb switches at home?
The cable standard provides performance of up to 100 MHz and is suitable for 10BASE-T, 100BASE-TX (Fast Ethernet), and 1000BASE-T (Gigabit Ethernet)
Posted : 19/03/2015 10:29 am
Thought cat 5 was only suitable up to 100Mbps? Link from modem to router needs to be at least 200Mbps shirley?
Posted : 19/03/2015 10:30 am
5e
Posted : 19/03/2015 10:32 am
Just called him and told him not to bother running the 7 but to just leave something for me to draw a 5e or 6 through with.
No doubt it'll snap or snag while I'm pulling it and I'll end up with floors up anyway.
Posted : 19/03/2015 10:33 am
http://www.lifehacker.com.au/2013/04/ask-lh-whats-the-difference-between-cat5-cat5e-and-cat6-cables/
How fast is the disc access on the end of the line?
Posted : 19/03/2015 10:34 am
Well, it'll be used for wifes work VPN, downloading and HD netflix possibly at the same time so even if the PCs are using SATA the total throughput will be more than 100Mbps.
And we've only gone for 200Mbps as we have to have FTTP as there's no FTTC in our street.
And its ordered now so there's no changing that bit.
Posted : 19/03/2015 10:37 am
 ton
I sell cat 5 and 6. cat 7 gathers dust.
Posted : 19/03/2015 10:39 am
Running with 50mbit fttp here hard to tell the difference between that and 25. It's the other end that has the problems these days and I can load mine up to those levels too on cat 5e.
Posted : 19/03/2015 10:41 am
I have CAT 5e internally and run it at 1 Gbps, much easier to work with than the others.
Posted : 19/03/2015 10:49 am
Never before has a thread meant so little to me. 😕
As you were.
Posted : 19/03/2015 10:50 am
Part of the issue here is that I dont know a lot about it either, I didnt know cat 7 existed till he phoned up!
Posted : 19/03/2015 10:53 am
 IA
FWIW get a better router than the HH if you're using wifi at all.
Just upgraded to an Asus DSL-A68U and it's _so_ much faster wifi (even on non-ac devices) on both 2.4 and 5gig. They do a version without the VDSL modem too as you won't need it.
I'm on a 70Mbps line and notice the difference, so on 200 you will too.
Also cat 5e fine here for me too...
Posted : 19/03/2015 11:01 am
Cool, I'll have a look into that as a few things will be on wifi.
More expense!
Posted : 19/03/2015 11:06 am
Cat5e now good for up to 5Gbps Cat6a up to 10Gbps (NBASE-T)
Posted : 19/03/2015 11:32 am
Aside from anything else,
CAT6 and upwards have considerably more stringent installation requirements than their predecessors. With all due respect, if you're posting on a cycling forum asking what colours the wires should be, what you're going to end up with is highly unlikely to be a CAT6 installation despite what it might have printed on the cable.
There is little to no point in using anything other than CAT5e in a DIY home installation. Anyone who tells you any different is probably trying to sell you cable. Oh, and CAT7 isn't a real standard, by the time it's ratified it'll probably go straight to CAT8.
Posted : 19/03/2015 11:33 am
No offence taken, I know my limitations hence asking!
Maybe I should have worded the question different...
If I put my router in a different location to my modem when using BT Infinity 200Mbps, what type of cable do I need between the two?
Posted : 19/03/2015 11:37 am
What is the cost of FTTP from BT? Work have issues with really slow connection and the local cabinet for the industrial estate isn't lit up. A fat pipe in would be nice.
Posted : 19/03/2015 11:53 am
Line rental £16.99 (which we won't use and don't actually need with FTTP but I don't think they'll let you just have the FTTP).
Broadband and calls £39.65
No installation charge.
So, a lot. However we had sky TV in the old house, for tv, phone and bb from sky it was somewhere just over £50 so not much difference in our outgoings, just however much extra it is for netflix and it makes my wifes life a lot easier when she syncs her 500mb PST files with work on a 20 mbps upload rather than the 1 mbps she had to use!
Edit: oh and £100 topcashback.
Posted : 19/03/2015 11:57 am
Posted : 19/03/2015 12:02 pm
Posted : 19/03/2015 12:04 pm
