Carrying water with...
[Closed] Carrying water without backpack
34 Users
 ad4m
Basically fed up of using backpack and bladders and looking to put all my equipment on my bike (tube, multitool etc). Plenty of solutions out there for that, but what about water?
Have a bottle cage on the bike, but for longer 3/4 hour rides 1 bottle isn't enough, so what would be a good solution in this case to carry water without using a backpack?
Posted : 16/08/2019 1:31 pm
A waist pack, or fanny pack or whatever it is called. I just bought a Dakine Hot Laps 5L and love it. Others are a available.
Posted : 16/08/2019 1:37 pm
fill the bottle up?
Posted : 16/08/2019 1:39 pm
Second bottle cage? It is possible even without bosses.
And/or plan routes that go via a tap?
Posted : 16/08/2019 1:40 pm
Stop at the pub for a pint or two halfway.
 feed
Cycling top with pockets and Hydramate (or similar) foldable water bottles ?
Posted : 16/08/2019 1:43 pm
Use mountain rescue water stops.
Posted : 16/08/2019 1:45 pm
Get bigger bottle. Second bottle on bike. Refill single bottle part way round at pub/church/cafe. Take filter and use a stream to refill. Use a bumbag/waist pack
Posted : 16/08/2019 1:46 pm
 Keva
I've a 1litre water bottle, well 980ml that will do me for three hours so long as it's not baking hot. maybe find a pub or water tap somewhere to top it up with if you run low? There's couple of places on route where I ride that have outside taps. One of them has a mint bush next to the tap so I stick some mint leaves in there as well 🙂
Posted : 16/08/2019 1:47 pm
 Yak
Sort your bike for 2 bottles and storage. This sort of thing:
Posted : 16/08/2019 1:49 pm
One of those cages the fit behind the saddle? Unfortunately you may be mistaken for a triathlete.
Posted : 16/08/2019 3:08 pm
Plug any holes in the frame and fill that up. Remove the seat tube when you need a slurp.
Posted : 16/08/2019 4:01 pm
If you really want more water frame bag with your camel back bladder in it?
Posted : 16/08/2019 5:06 pm
2x 750ml bottles will keep you riding for 3-4hrs unless it's really hot. If you want more, then a bladder in a frame bag is what I've used for really long rides.
Posted : 16/08/2019 5:14 pm
Raceface does - or did - a top that incorporates a reservoir pocket.
https://www.raceface.com/products/details/stash-mens-tank-18
Never used one, but it does exist. I suspect someone else will do something similar too, though I can't think who offhand. Camelbak used to do one, i think, but no idea if it still exists.
Posted : 16/08/2019 5:19 pm
Just wear one of those stillsuits. If it's good enough for the Fremen...
Posted : 16/08/2019 5:23 pm
Raceface does – or did – a top that incorporates a reservoir pocket.
/a>
Never used one, but it does exist. I suspect someone else will do something similar too, though I can’t think who offhand. Camelbak used to do one, i think, but no idea if it still exists.
I have the RaceFace. The additional pockets are great but the reservoir holder not so much. For a start, it's impossible to remove and/or refill the bladder when wearing it. The additional support needed for the bladder also makes the back panel very sweaty, even when there's no reservoir present.
Endura now do a very similar - Singletrack - bib-short but in a lighter material. I'd look at one of them first (though the refill thing will remain an issue on longer rides).
The RaceFace is now reserved for Winter use as having the reservoir/hose close to the body and under outer layers means they don't freeze up.
Posted : 16/08/2019 5:28 pm
https://www.halfords.com/cycling/bike-accessories/bike-bottles-cages/topeak-bottle-cage-mount
Mount on bars or seatpost, £3 before BC discount!
Posted : 16/08/2019 5:49 pm
Alpkit stem cell (other brands are available) and a Nalgene.
Bikepacking on my full suss, one bottle in cage in frame, nalgene in stem cell and another bottle on the bars using an adapter/bottle cage.
Posted : 16/08/2019 7:25 pm
You could always make a Zippomatic 2000 drinks master. Costs less than a tenner.
Posted : 16/08/2019 7:35 pm
I ride with a dakines 2 lire hot lap that allows for an external water bottle to be mounted to the outside of the bag and store bits & bobs in the bag. Run a cage on the frame and swop out the bottle once it is empty.
Posted : 16/08/2019 10:16 pm
For my doorstep riding i use a single 750ml bottle & i've got a network of outside taps that i use: second hand car dealer, church, scout hut, working mans club, camp sites etc. Be resourceful it makes resupply an element of a ride. If you are somewhere a bit more out there a Sawyer water filter would do the trick. I also have the Dakine Hot Laps 2 & can add another bottle, but tend to only do this if crazy hot.
Posted : 16/08/2019 10:28 pm
Surely there are others that use a water filter and help themselves to streams / rivers etc?
I use a "Water-well": means I only ever carry 700cc but top up regularly. There are probably better versions. Wont work everywhere obviously (in my head especially I wont use it downstream from human habitation- but I'm not sure that's founded).
Fill up your stomach with water before you head out, it will easily hold a an extra litre.
With that and a 750ml bottle, 4 hours should be fine unless you are racing up Mt Diablo in California in July or something.
Posted : 17/08/2019 12:59 am
I read somewhere (cycling weekly?) You don't need as much water as you think you do.
Posted : 17/08/2019 1:16 am
I read somewhere (cycling weekly?) You don’t need as much water as you think you do.
Exactly.
Posted : 17/08/2019 1:18 am
3rded. I find it incredible the amount of water some of you take. You take more water for a couple of hours cycling in the UK than I need for 10 hours exercise in 30 degree heat
Posted : 17/08/2019 7:50 am
If the zippomatic isn’t to your liking , runner’s bottles are easy to attach anywhere.
I normally strap one to my handlebars with a toe clip strap. An easy way to carry half a litre.
Posted : 17/08/2019 9:05 am
It's one of the great joys of sports science that you can find research supporting just about anything you want to believe - the answer is probably something along the lines of 'it depends'.
Posted : 17/08/2019 9:37 am
 ad4m
Some interesting suggestions here. I can't really refill anywhere near the trail so need to take all my water with me. Tempted by putting a bottle on the frame and using one of these lightweight hip packs that trail runners use so I have two bottles, and put the tools/tubes on the frame.
Posted : 20/08/2019 12:08 am
I use a folding water bottle
You can carry them in a pocket or strap them to the bike using some velcro strapping
Once finished with you just fold them up and stuff them in a pocket, only cost £1 too
https://www.sportsdirect.com/sportsdirect-folding-water-bottle-898108#colcode=89810818
Posted : 20/08/2019 4:56 am
I have one of these for the times when I need more water
https://backbottle.com/
Works really well, not a big bottle, but easy to use and get in and out of your pockets
Posted : 20/08/2019 6:43 am
It’s one of the great joys of sports science that you can find research supporting just about anything you want to believe – the answer is probably something along the lines of ‘it depends’.
+1 it's a daft statement to make.
E.g. I can do a 6hr road ride in summer on 2l of water and a pint of lemonade at the pub halfway, but I'm a dehydrated mess barely able to turn the pedals by the end.
I can also take a 3l Camelback to Swinley and drink it all. And not need a pee either, just 2h doing laps at a high intensity.
The latter is probably closer to an equilibrium. I could probably do a lap of Swinley with no water (or drinking before the start) but that's not something that could be extrapolated!
Posted : 20/08/2019 10:10 am
A) We're all different.
B) Depends on how (physically) hard you are riding.
C) Depends on the weather.
I'd like to know where the OP is riding that they aren't near a water supply of some sort for three to four hours.
Posted : 20/08/2019 10:19 am
As all roadies know, one of the most effective ways to lose weight off your bike is to pay your mate to carry your 1 litre bottle i.e. one kilo and ride alongside you, handing it to you whenever you are thirsty.
Do this. It's a win:win.
Posted : 20/08/2019 1:36 pm
I’d like to know where the OP is riding that they aren’t near a water supply of some sort for three to four hours.
Why?
I can spend three to four hours riding the local woods, about two miles from a pub or shop. It doesn’t mean that I’ll ever use those places when I can carry all the water and food I need. It’s also only four miles from home, so I could ride back when I need a slurp. 🙄
Posted : 20/08/2019 2:01 pm
The latter is probably closer to an equilibrium. I could probably do a lap of Swinley with no water (or drinking before the start) but that’s not something that could be extrapolated!
forgot my bottle for a Swinley ride once. Was gagging to the point of literally vomiting after 40 minutes. Evening in October.
Posted : 20/08/2019 6:22 pm
Gorilla cage or equivalent fitted to the normal cage mounts, plus 2L fizzy drinks/cider bottle.
Posted : 20/08/2019 8:43 pm
Nathan runner belt - two small bottles for evening rides. + frame bottle for long ones. Drink a pint before you start.. frame bag for tube etc.
Posted : 21/08/2019 12:02 pm
