Car tyre repair?
[Closed] Car tyre repair?
9 Users
 bruk
We are away for a few days up in Dundee for a break when I notice the near side rear looks a little soft. Pump it up with the pump then close inspection shows a nail in the middle part of the tread, ie one of the deep grooves, seems to be holding so must be a slowish puncture.
Non run flats, anyone know if that can be repaired and if so where in Dundee is good and trustworthy?
Posted : 12/04/2015 9:16 pm
Franks fast fit in dundee
If your in the arbroath side then arbroat mconecheys pretty good. Run by an old mate.
Posted : 12/04/2015 9:18 pm
Should be OK to be repaired I think. Usually they won;t do it if it's in or near the sidewall.
Posted : 12/04/2015 9:20 pm
easy fix if in middle of tyre - just check you have enough tread left to make the repair worthwhile - under 3mm i'd just get a new tyre
Posted : 12/04/2015 9:21 pm
As long there as isn't damage to the wall or cracks - tyre places will soon tell you how bad it is.
Posted : 12/04/2015 9:23 pm
 bruk
Cheers for that. Winter wheels due to come off when we get home but still a decent amount of tread, certainly another season as a full winter left in them. Staying out Broughty Ferry way so will check out those ones thanks TR.
Posted : 12/04/2015 9:28 pm
Had this week, nail in tyre less than 10k miles near but not at sidewall. Lots of teeth sucking he declared that I needed a new tyre.
I questioned this and did mucho googling until I found the nail was was well within the area T that repairs can be done. They were clearly after a new tyre off me.
Posted : 12/04/2015 9:33 pm
 bruk
Yeah, that's kind of why I want to find somewhere kind of trustworthy so don't get ripped off.
Posted : 12/04/2015 9:42 pm
Centre of the tread is a repairable area, the problem comes when a tyre is run too much whilst under the correct tyre pressure, as it damages the structure of the sidewalls, which then renders it dangerous to carry on using.
Posted : 12/04/2015 9:46 pm
[url= http://www.etyres.co.uk/punctures/can-my-puncture-be-repaired/ ]http://www.etyres.co.uk/punctures/can-my-puncture-be-repaired/[/url]
 bruk
Cheers Bruneep, will take a copy with me.
Posted : 12/04/2015 10:51 pm
I've used tubeless repair anchovies in motorbike tyres and car tyres to good effect, although obviously I wouldn't recommend anyone else do so as certain death awaits.
Posted : 13/04/2015 12:05 am
The last time I enquired about a puncture repair they said the rules were if it is within the central 3/4 of the tyre width and the tyre hasn't been completely flat then you're ok. If its gone completely flat then the rim crimping/pinching the sidewall could have caused structural damage to the tyre sidewall (though I don't know how they can be sure the tyre hasn't been allowed to fully deflate - they only have your word to go off). Anything near or in the sidewall is a no no apparently.
Posted : 13/04/2015 9:04 am
You can see wear in the inside of the tyre, and there is usually a load of rubber dust if it's been seriously under inflated and run.
Posted : 13/04/2015 12:20 pm
