car mechanics help ...
[Closed] car mechanics help please- quack/duck noise on start up? no joke
33 Users
Hello, have a little kangoo van, when I start the car I get a short 1second 'quack' type noise from the engine bay...its a bit odd, any ideas please?
Never heard it until I recently had belts etc changed?
Petrol, 1.2, 2002
Posted : 31/10/2012 2:45 pm
Is it a duck?
Posted : 31/10/2012 2:47 pm
this thread is not going to go well.
i think you're quackers mate.
Posted : 31/10/2012 2:48 pm
[i]Is it a duck? [/i]
you'd have to be quackers to think that.
[edit] too late with the quackers joke.
Does it smell fowl?
Posted : 31/10/2012 2:50 pm
Have you tried feathering the throttle?
I fear it could result in a hefty bill.
Posted : 31/10/2012 2:51 pm
Don't get down about it.
Posted : 31/10/2012 2:52 pm
Eider get a mate to put his head under the bonnet when you start it up.
Posted : 31/10/2012 2:53 pm
Yes, let someone have a gander at it.
Posted : 31/10/2012 2:54 pm
Kangaroo making duck noise you say?
We had a Rover with a fan belt that sounded like a canary, I called Rolf Harris and then saught psychiatric help.
Posted : 31/10/2012 2:56 pm
don't go swanning into any garages, demanding a fix - it's goosed 🙁
is this it ?
Posted : 31/10/2012 3:00 pm
that's enough ruddy duck jokes.
Posted : 31/10/2012 3:01 pm
maybe this one ?
Posted : 31/10/2012 3:02 pm
Do you wear a cygnet ring?
Were you ugly when you were small?
Bah.....funny men 😀
Any real mechanics?
 pdw
Sorry for not getting into the spirit of the thread but:
Starter motor not disengaging immediately.
Posted : 31/10/2012 3:04 pm
Boooooooooooooooooooooooooooooo!
But yes, that doesn't sound far off.
Posted : 31/10/2012 3:05 pm
Yep, sounds like the inertia mechanism on SM is Mullard 😉
I see thank you! Easy to fix or replace starter motor?
Guessing it will eventually knacker the starter?
Posted : 31/10/2012 3:26 pm
 ski
Bah.....funny men
Any real mechanics?
Posted : 31/10/2012 3:30 pm
Common problem with these. I fear your goose is cooked.
Posted : 31/10/2012 3:33 pm
problem you'll have is that the teeth on the flywheel may get damaged if you don;t get the starter sorted - and then it'll get expensive to fix.
Posted : 31/10/2012 3:34 pm
Is it the Platypus valve? Hefty bill if you cant duck it.
Posted : 31/10/2012 3:38 pm
If it's a dead duck, the noise problem is fixed?
Unless it's a ....ghost duck....
Posted : 31/10/2012 3:39 pm
Could also be a slipping belt now that the weather is a bit colder.
However, it is French, so you may as well get used to it making funny noises.
Posted : 31/10/2012 3:48 pm
If it's the starter it could mean a big bill, so you won't be able to swan around in your van. If it's French, does it it quack in pidgin English?
Posted : 31/10/2012 3:53 pm
Kanckered?
It'll be totally Donald Ducked mate.
Posted : 31/10/2012 4:00 pm
Malfunctioning audible low obstacle warning?
Posted : 31/10/2012 4:07 pm
Before the engine fires? Fuel pump.
After engine fires? Starter. Take the starter off and lube it, so that it retracts properly. You can get gunge build-up. That sorts it 90% of the time. WD40 or GT85 to free it, then the lightest oil you have kicking about (chain lube works great).
Posted : 31/10/2012 5:22 pm
Can I just say "sticky bendix" please - on-topicish, and one of my favourite phrases from mini-owning days
Posted : 31/10/2012 5:37 pm
Try starting engine with clutch down then with clutch up; release bearing?
Or EGR valve opening and closing;servo vacuum loss? try pinching the hose to the EGR and see if it stops.
Posted : 31/10/2012 5:49 pm
More than likely a loose drive belt. Give em a spray with WD40 and if noise goes away either tension or replace. It will have a pre engaged starter so need sticky bendix available.
Posted : 31/10/2012 6:17 pm
Sounds like it could be a quack in the windscreen.
Posted : 31/10/2012 7:19 pm
Did you buy it 2nd hand? Once Bittern, twice shy I always say.
Posted : 31/10/2012 7:23 pm
Customer: My van makes a duck sound when I drive it.
Garage: What van is it?
Customer: Renault
Garage: French?
Customer: Cunard
Garage:Bloody right is it, I was terrible at language at School!
Posted : 31/10/2012 7:28 pm
Make sure you pay the bill or they'll put you up in front of a beak.
Posted : 31/10/2012 7:32 pm
or not engaging would make the same noise?
Posted : 31/10/2012 7:33 pm
....wow you folks must be bored! Very impressed with the duck related humour 😛
Thanks yeah starter motor makes sense I will take it off and have a clean, much appreciated, have to duck out now lots of chicks to pick up in my sweeet ride 😀
Posted : 31/10/2012 9:17 pm
Enough of the wisequacks. Last thing the OP needs is to break down in this fowl weather.
Posted : 31/10/2012 9:26 pm
Posted : 31/10/2012 11:51 pm
pdw - Member
He's right you know.
That's a feather in his cap.
Posted : 01/11/2012 1:35 am
Was it the starter motor walla? Have we got to the bottom of this mallard-y?
Posted : 01/11/2012 2:02 pm
I hope this thread hasn't driven you daffy, or we'll all be treading on eggshells.
Did you find a new home for the duck (once you coaxed it out from under the bonnet)?
Posted : 01/11/2012 3:00 pm
When it does start does it go OK, is it a runner?
Runner?
Get it?
Anyway, enough duck puns, I'm off to get some dinner now, I'm a bit peckish.
Posted : 02/11/2012 12:01 am
Come on guys and gulls, I'm sure we can keep this going.
Posted : 02/11/2012 9:25 pm
OP, was it a quackastrophe orville the van start now?
Posted : 19/12/2012 2:21 pm
Try not to get down about it.
Posted : 19/12/2012 2:28 pm
he's been hatching a plan to get it fixed.
A 2002 Kangoo? That's almost old enough to be a classic. You should definately get this problem fixed, keep it in tip top condition.
One day it could be top of the bill in a classic car show, you might be sitting on a real nest-egg there.
Posted : 19/12/2012 5:03 pm
Since it's French you canard-ly expect it to be reliable!
Posted : 19/12/2012 5:37 pm
Posted : 19/12/2012 6:07 pm
^ priceless!
Posted : 19/12/2012 6:43 pm
Posted : 19/12/2012 10:17 pm
wwaswas - Member
this. this made me guffaw.
as did "feathering the throttle".
Posted : 19/12/2012 10:25 pm
