Long shot, but are there any common problems that would cause the engine light to go on original focus.
Only had the car a month it squeals when I start the car for 30 secs or until I move off.
I know sweet FA about cars.
Plenty of things will turn the light on get the fault codes read is the best way to do it or you just end up changing bits for the sake of it. Maybe get a code reader of eBay if you fancy having a go yourself.
What one is it? If it's the 1.8 TDDI, then engine light means basically anything at all, the diagnostics are terrible. Ford dealer insisted there was a fault in the cam sensor it doesn't have.
Whereabouts are you? My code reader'll do 1st gens I think, though it might not tell you a lot.
Squeal is probably a slipping belt.
You need to get it plugged into an OBD reader, it'll tell you what's going on.
Cougar - ModeratorSqueal is probably a slipping belt.
^^^ this.
I got the ABS light on constantly on my Corolla recently but it was merely dirt sticking to the fluid reservior where the sensor is located. Poked it a bit with paper clip to make sure it's unstuck, now everything is normal again. [b] But I would not advise you to do so.[/b]
Take out new for old insurance. Torch it.
I'm based near Cambridge. Will any garage have an OBD reader, as I trust mechanics as much as I trust recruitment agents.
tails - MemberI'm based near Cambridge. Will any garage have an OBD reader, as I trust mechanics as much as I trust recruitment agents.
Some cowboys would probably need you to change the whole engine ...
Try this to search for reliable garages but take it with a pinch of salt.
[url= http://www.yell.com/ucs/UcsSearchAction.do?keywords=Garage+Services&location=cambridge&scrambleSeed=468427075 ]Garage search with reviews[/url]
Buy one its cheaper than a visit to the garage and you've got it for future use.
craigxxl - MemberBuy one its cheaper than a visit to the garage and you've got it for future use.
This ^^^ the best option.
Good idea as they are only £15, where do I plug it in 😳
Also will it work with OSX on my mac or windows only?
Normally a pull down port under your steering column. F Super I would have recommended but don't think it works with osx. Try a standalone reader from eBay
Like this http://www.ebay.co.uk/itm/Car-fault-reader-code-scanner-diagnostic-tool-OBD-2-CAN-/230644533100
On my old mondo putting a tank of decent fuel rather than el cheapo fuel would get rid of the EML most of the time.
It's a Ford.
The engine light is probably broken.
That will do it
Thanks for putting your trust in us mechanics, what engine is it? I've worked on Fords for 18yrs so might know what it could be. 😉
haha! I'll buy one of those machines and post back up here.
So I bought one and it scans and the says link error. What will a garage do or is there another connection I can use? I'm slightly concerned as one of the main selling points is that they can delete all error codes, I'm worried the last chap deleted all error codes before selling the car.
Only one port to plug into. Silly question but it is fully pushed in as they can be tight?
Also, under new laws it won't pass MOT with any light on, on the dash.
Depending on the year, they have a self diagnostic program on them.
Have a read here it may help.
http://www.fordownersclub.com/forums/lofiversion/index.php?t1486-0.html
jekkyl - Member
That's not true.
Any warning light on the dash is now a MOT fail since March as pointed out by Jekkyl
Really? Any more made up rules you'd like me to fail cars on tomorrow?
Yes, I just make this up for fun or maybe you should read [url= http://www.dft.gov.uk/vosa/repository/CHANGES%20TO%20THE%20MOT%20TEST%20EFFECTIVE%20FROM%2020%20MARCH%202013.pdf ]this[/url].
Yes it was. . . . the second time I tested! 😳
As it states it's a connection fault. Do you know someone else with a Ford that you can test the code reader with to ensure it's working correctly. If not working send back and replace. If the socket on your car is faulty then I don't how to get around it.
I have read it thanks. In fact it's pinned up on the wall next to the MOT computer in work.
Could you highlight where it says an engine management light being on is now a fail, I may have missed it.
Ring an MOT garage & ask them.
I have read it thanks. In fact it's pinned up on the wall next to the MOT computer in work.Could you highlight where it says an engine management light being on is now a fail, I may have missed it.
To be fair, I'm not sure he claimed that one specifically. It was a more general statement of fact.
Got your ignition turned on when connecting?
Had a read through that document and couldnt see it saying anywhere that an engine warning light was a fail- stability control, power streering etc aye, but no note of engine management light on there.
That change got picked up wrongly in a lot of places, it went from "some warning lights are MOT fails" to "warning lights are now MOT fails" to "all warning lights are MOT fails".
Still waiting to find out if anyone will notice my de-cat 😳
Depends on whether it fails emissions.
Aye, it still ought to pass the emissions test but the de-cat's a fail now in its own right if it's noticed. OTOH you can only see that it's missing from exactly one place, with a torch, so it's probably not that likely. We shall see...
Still got the cat but it's a knuckle-ripper getting it in and out.
I hope its not a 1.6 diesel, friend of mine has just had this problem on a 55 plate. Turns out there is a big problem with the oil supply to the turbo. The supply pipe get blocked as the engine gets clogged up with carbon deposits. this causes the turbo to fail and most often requires a whole new engine as well.
Are you still OK to decat diesels?
Are you still driving round or have you actually gone into a garage?
**** mucking about with readers, if my engine light was on and there was a noise from the engine it wouldn't be driven/would be with a mechanic.
I had a shriek-sound from a Focus on set off, it was the clutch release bearing however there was no engine light lit.
I don't need to ring and ask. I'm a MOT tester.
If it's wrong, it's not a fact.
Tyre pressure lights only apply to cars registered after Jan 12 also.
I was on the misunderstanding that it was all warning lights so I was wrong and Dai is correct. However the quote below
Dai - Memberjekkyl - Member
Also, under new laws it won't pass MOT with any light on, on the dash.That's not true.
Isn't correct either as it seems to be all but the engine warning light and the reason this seems to be excluded at the moment is down to it being a warning for a multitude of faults. As I understand, rightly or wrongly, is that not all MOT tester have the equipment to check the specific fault or if there is a fault and the lamp has been disabled hence why it currently excluded. Since most engine warning light relate to emissions sensors I would expect it to included in the future as fail but currently Dai is correct and it won't fail for this lamp being lit.
