There's 8 questions about choices on purchase and repair of consumer goods:
https://forms.gle/PCkAwBFaBSHT6xyRA
It's a google form so works like a standard online survey - just tick boxes and hit submit.
Thanks in advance if you complete it.
Done.
Instructions?
Just take it apart to see how it works is my preferred method.
Done
I think California were about to introduce a right to repair law - Sonos are the worst offenders but Apple are pretty bad!
John Deere are always held up as the worst offender, funnily. If the tractor decides it needs some attention it will literally not restart until an authorised repairer has plugged a laptop in and confirmed the work has been carried out.
There's now a whole industry in Ukraine devoted to cracking their software and providing downloadable toolsets for telling the on board computers that a repair/service has been done by an authorised dealer.
Done
I think there are going to be some regulations in Europe on repair-ability and availability of spare parts, but without some regulation on the price of the spare parts it isn't as useful as it might be although it might create a market for 'breakers'
https://eeb.org/europe-paves-way-for-right-to-repair/
done
Doneski.
Done.
Good subject.
Done. Replacement instead of repairing is the elephant in the room when it comes to ‘greening’ our way of life. Most people recognise its importance but most people want the latest new shiny thing.
Done
Link doesn't work on my phone, tries to redirect to Google Play.
Done. Interesting questions
Done, and especailly relevant as I pulled a probably 20+ year old dyson dc01 to bits at the weekend to work out why it had stopped sucking properly, looks like the impeller bearing was the culprit, as it was very hard to turn, I think the quantities of plaster ducst it's sucked up ove the years finally overcame the seals, hopefully the £4 replacement will sort it for another decade or two.
Done - thought provoking - thanks!
Done.
Yep, good topic. I had to put on my rose tinted glasses before answering "Do you think that modern electronic devices are harder to repair than older items? "
Yes, done.
Very good.
Last question should really be separated, I answered unsure, purely because I do believe in a right to repair, but not necessarily that manufacturers should make things easily repairable, as that could possibly stifle innovation and lead to a technological plateau for consumers.
Done. And you tell your son that he's made a better job of designing the survey than most do.
Done, and what Grey beard said.
Done
Done, I love taking stuff apart and occasionally putting it back together successfully.
Done. The last question should include an explanation / link to an explanation of what the right to repair is, or possibly be split into a series of sub questions. I answered unsure as I do think that people should be allowed to repair stuff, but also see a lot of potential issues with designing mass consumer items to be easy to dismantle and work on.
Also, I'm sure that less questions leads to more responses but I (and I suspect a lot of others) pretty much ticked every option on every question as they are all quite general!
Done
Done
Do you think that modern electronic devices are harder to repair than older items? *
Needed more nuance.
I've taken really old stuff apart and been unable to repair it due to unavailable parts or lack of skill, or just a severe case of the CBA's when there's lots of working ecamples on ebay. But the repair can just require time rather than money or parts (e.g. cracked solder joins or a bit or ribbon wire) conversely if a laptop PC component fails, you just fit a new part which is pretty much plug and play, as long as it's available.
Needs a bit more clarification about what goods the survey is aimed at - it refers to 'electronic goods', which to my mind excludes white goods, cars and similar which is what I think should be the target of any law changes.
IMO, electronic goods are never going to be 'repairable' by the average consumer unless part replacement is made as simple as battery replacement ie a modular plug in structure, with easy diagnosis, and that's going to mean big compromises to the design of devices.
Done. I love trying to repair stuff but it often ends up being extremely infuriating. I do actively consider ease of repair when buying stuff now.
Recent wins include a Gaggia Classic coffee machine, Dyson V6 vacuum, Dualit toaster, G-Shock watch (strap).
Recent loses include AEG washing machine (impossible to change door seal without removing counter balance which crumbles when you touch it), AEG tumble dryer (leaking moist air from every conceivable gap - impossible to put bac together), the wife's haird dryer.
Done survey, over the years I’ve lost count of the times a power tool has suddenly stopped working and an hour or so later after taking it apart it’s going again. We need to adopt more make do and mend as opposed to throw away and buy new.
IMO, electronic goods are never going to be ‘repairable’ by the average consumer unless part replacement is made as simple as battery replacement ie a modular plug in structure, with easy diagnosis, and that’s going to mean big compromises to the design of devices.
I hear what you’re saying, but I don’t think that it’s entirely true. It’s bloodyminded manufacturing/design decisions that are infuriating. Stuff doesn’t need to be made ‘easy’ to repair, it needs to be possible, by someone reasonably skilled, that’s all.
It’s at best lazy design and at worst it’s deliberate built in obsolescence that is the problem; which should be illegal. It’s as anti green as plastics and fossil fuels in my mind.
I bought a previous-generation Macbook as they were just making the change from screws and pins to glue and solder. Very helpful when I changed to a SSD and replaced the battery.
Best fixing 'win' was sending a second hand DeLonghi coffee machine for repair, getting quoted over £200 for the fix, declining and asking for it to be sent back for a DIY job, but finding they had fixed it anyway without charging me.
Over a 120 responses from singletrack so far - thanks everyone 🙂
121 🙂
Done, good survey that
Done.
Done
Done
Be nice to see things that will wear (such as washing machine bearings etc etc) having maintainability built in, ditto electrics at a sensible component level.
“We need to adopt more make do and mend as opposed to throw away and buy new.”
We used to have this, in our case it was based on a lower standard of living (less money so more inclined to repair), less ‘integrated/sophisticated’ devices so often more possible to repair, different attitude w.r.t stuff (keeping up with the jones seemed to be a lot less of an issue). When I was very young we used to go to the dump and come back with stuff, it doesn’t work that way now and I suspect that an awful lot of people wouldn’t contemplate that way of life. I still always look in every skip I pass...........
Done.
Done.
Yeah, I love a good home repair.
Responded. Not that I'm really the person to ask about these things, but at least it gives a wider representation of respondents!
Done. Would be interested to know how the responses would compare to non electronic item. I appreciate most items have some electronics in these days, regards of the benefit they add.
Please publish results at some point. Keen to know the consensus, assume (naturally) most people are similar to me.
Done,
Echoing the responses bove.
Interesting Questions
Thoght provoking
I'd actually quite like to know what he does with it.
To add hipsetr points I have pointed him in the direction of la pavoni as a n example of repairable/buy it and fix it.
Done - but did he mean electronic goods? For me this is iPhones, TVs and iPads. I’m not sure if these will ever be everyday people repairs on the other hand electric goods, ie kettles, washing machines, the Mira shower (I replace the boiler every other year), dryers, vacuum cleaners, - I feel these should be much more repairable. The hard middle ground are the modern cordless drill/screwdrivers and similar things, probably as electronic as electric ... and modern cars..
The thing about modern electronics is they need specialist testing kit to check, where as electrics and a basic multimeter will crack it.
Survey done.
Recently replaced the li-ion batterys and cleaned the com in my Bosch vacuum cleaner.
Not sure if that counts as electronic but deffinatly repairing stuff.
New motor and battery assembly = £350
New Cleaner = £250
Repair cost = £45
Done
guessing there are dozens of "other - bike lights" on there then !
Does your son have.............. The knack?
Survey done.
Does your son have………….. The knack?
He's on target to get a 1st in Computer Science and has recently removed and is rebuilding the rear subframe on his 1988 Mini 🙂
I'll see what I can do re: access to the results for those that have asked. I think it follows from his original plan for his final year project which revolved around a sort of 'exploded diagram' method of repair but using a set of tutorials to take people through dismantling things and printing labels to keep parts together when stored - almost like a reverse IKEA build sheet you start with the complete part and end up with a set of labeled components - linking the parts to online resources to buy replacements and then showing the rebuild process. He was going to use his Mini as a case study as there's a wealth of online info and parts suppliers.
Survey completed.
Did it.
I think most of the "problem" of non repairability of modern consumer electronics comes from the integration and specific design. Virtually nothing is made of standard components any more and no company wants to manufacture and warehouse "spare parts" for ever and a day. It's just going to sit there eating up space and capital and the pay back, for anyone else to hold it, is tiny.
Imagine an iphone made of "off the shelf" components - it'd be huge. Bigger stuff is fine.
Great idea by the way though I'm not sure how you'd monetise it.
The question that all the research will lead to is: "would you pay more on the off chance you could repair the device or would you rather pay less ?".
Link not working from me.
Sounds right up my street too. Although it sounds like he should have included more than electronic items. I would second the call for car to be included.
sorry, just tried it in Firefox and it's ok for me.
Over 250 responses from Singletrack now 🙂
Good stuff. I suspect stw is probably a bit biased to home fixed given the propensity here to fettling and bodging.
One area that I think is reasonably well supported for spares is kitchen goods. The pcb running our extract shorted. Only took 5mins to get a replacement ordered and it should be here today on next day delivery. Easy to access too so should be a 5min fix. Same for oven elements etc. Washing machine was a ballache though and that looked like it wasn't designed for easy home fixing .
done. reduce, reuse , recycle
yes. He mentioned he hadn't asked for the age of the respondents either - I just said 'It's STW, they'll all be over 30' 😉
