Son has 2 v small led spots on his bike, but they need moving. There's a single black wire to each led. Ideally I'd disconnect at a connector, but I need to remove much fairing to access.
So can I cut the wire, and then re-solder?
Posted : 06/10/2025 3:52 pm
Yes but I would use crimps not solder as unless you get all the flux off and make the join 100% watertight the joint can corrode. This is a much disputed point tho - some folk prefer one some the other
Posted : 06/10/2025 3:56 pm
Yeah - put some bullet connectors or similar in so if you ever need to do it again it's easy.
Posted : 07/10/2025 3:35 am
