Can STW help me fin...
[Closed] Can STW help me find a hose reducer from 1" to 1/2"??
5 Users
Please?
Doesn't seem a popular size.
Need to go from 1" down to ½"
In brass as the plastic one I used 4 years ago just broke.
[url= https://i.ibb.co/dtX1p7q/10mm-8mm-3-8-5-16-steel-reducer-hose-connector-joiner-1900-p-ekm-320x320-ekm.jp g" target="_blank">https://i.ibb.co/dtX1p7q/10mm-8mm-3-8-5-16-steel-reducer-hose-connector-joiner-1900-p-ekm-320x320-ekm.jp g"/> [/img][/url]
Posted : 19/12/2018 6:46 pm
Larger one with a female thread and a smaller one with a male thread and screw them together?
Or two males and an interconnect?
Posted : 19/12/2018 6:50 pm
Good idea but still can't find anything at the moment.
Back to Google.
Posted : 19/12/2018 7:05 pm
have you tried 25(or 26) to 12 or 13mm ?
Posted : 19/12/2018 7:20 pm
Have a look for Geka couplings they should be able to do it.
Posted : 19/12/2018 7:23 pm
25 to 13 finds plenty of plastic ones, but no brass / metal.
Will take a look at Geka cheers.
Posted : 19/12/2018 7:29 pm
Aha, Geka will do it. How well do they look together? Well enough to hang under the back of a camper van and occasionally get bashed on the ground?
Posted : 19/12/2018 7:31 pm
They should be fine , we use them with our irrigation equipment so get dragged across concrete and occasionally get driven over.
Posted : 19/12/2018 7:34 pm
Thinking of Margaret Thatcher on a cold day tends to make my hose reduce from 1" to 1/2"... Not sure that's helpful for your purposes though?
Posted : 19/12/2018 8:32 pm
Sorted cheers. Finally found some barbs both with 1/2" threads and a coupler.
Posted : 19/12/2018 8:51 pm
