Can anyone recommen...
[Closed] Can anyone recommend a gas safe heating engineer in Brighton area ?
1 Users
Hi All
My old Potterton profile 60e boiler has been playing up for the last year ,  it gets stuck in the start up cycle (when system is running warm i.e. heating has been on - reached temperature and boiler switched off, then when heating drops below temp and it trys to start up again - so probably dry joints on pcb at fault)
A bang on the side usually fix's it
I have bought a replacement PCB board - which may fix it - But having opened up the front and looked at the rats nest of cables , i dont fancy fitting it myself and risking completely  borking the boiler
Can any recommend any one in the Brighton area to install the board ?
Alternatively whats the current go to boiler for doing a straight swap of a vented boiler (Not Combi), looking for something thats not going to need costly servicing every year -(Basically apart from hovering up soot from burners - nothing has been done to the potterton for the last 25 years..)
Posted : 07/09/2021 12:18 pm
