South Wales or West Mids perhaps?
A small portable tabletop jobbie would work well, a full sized one less so 🙂
EDIT or a scroll saw
What you cutting up?
Acrylic in 10mm sheets
What size,shape quantities?
A cheap jigsaw would probably be ok.
It's two A4 sized sheets that need to be in small 7cm ish squares. I have a jigsaw but straight lines aren't so easy freehand.
Send me the sheets I can cut them on the laser if you need polished edges or on the table saw if are okay with slightly rougher ones.
Mount the jigsaw upside down onto a piece of MDF/ply and screw a fence at whatever size you need.
And be careful as the blade isn't protected.
TheDTs - that's very kind, we do need polished edges in fact. I've emailed you 🙂
