Can anyone help me ...
[Closed] Can anyone help me with an Excel problem?
3 Users
Can anyone help me with the following problem?
I have an Excel spreadsheet to which a new worksheet is added each week. The new worksheet is named as the week number (i.e. "47" for this week). Does anyone know how I can make it open on the current worksheet regardless of which worksheet was open when it was last saved? I think it can be done with some vba code but I do not have the skills. Thanks.
Posted : 17/11/2015 12:09 pm
in VBA select the last worksheet then save as then it will open at that.
(probably a bad method)
Posted : 17/11/2015 12:12 pm
Thanks but I really need it to be seamless - I should have mentioned that there are a number of different users of the file.
Posted : 17/11/2015 12:19 pm
Stick that in "ThisWorkbook".
Basically counts your sheets. Then opens the sheet which equals the count. Stick a minus and a number behind Sheets.Count if you have extra sheets.
Private Sub Workbook_Open()
i = Sheets.Count
Worksheets(i).Activate
End Sub
Posted : 17/11/2015 12:20 pm
Then users who can't check what sheet they are on should not have access.
Posted : 17/11/2015 12:22 pm
PlopNofear thanks, that works fine!
MWS I agree with you but unfortunately they need to have access
Posted : 17/11/2015 12:40 pm
That is what controlled data entry is for, eg via a web page into a database
The consultant coming out in me, fixing the problem not the symptom
Posted : 17/11/2015 12:46 pm
