Can a shop legally ...
[Closed] Can a shop legally sell unused helmets that were manufactured 6 years ago?
13 Users
As the title says. I thought helmets had a 5 year shelf life? Got a heavily discounted helmet yesterday. Says it's a 2020 model on the website but the label inside the helmet says it was manufactured in 2014!
Still safe to use do you think?
Posted : 04/07/2020 12:21 pm
Test it to see if its fit for purpose...
Posted : 04/07/2020 12:26 pm
"I thought helmets had a 5 year shelf life?"
Then you thought wrong. Some manufacturers may suggest a 5 year life but that is from the rigours of typical use, not being stored, or even lightly used.
Posted : 04/07/2020 12:30 pm
Not sure they can call a helmet made in 2014 a 2020 model, but a helmet made in 2014 and stored in a box in cool environment will be fine.
Would be miffed if I thought I'd ordered a 2020 design and a 2014 one arrived however.
Posted : 04/07/2020 12:33 pm
SNELL the testing organisation say 10yrs...
Posted : 04/07/2020 12:38 pm
For construction site hard hats widely used guidelines are 5 years from manufacture and/or 3 years from date of issue (assuming good storage and no damage) - but these are only guidelines - there's nothing in HSE regulations.
Posted : 04/07/2020 12:41 pm
Impact damage, high temperature, rough handling and UV light degrade a helmet. I know when i did my mountain bike leaders course my helmet age at 5 years was frowned on, despite no impacts and being stored in the dark. Still be a bit miffed at getting 6 year old stock if bought new, if it was discounted because if age and that was clear I'd be happy.
Posted : 04/07/2020 12:50 pm
I think marketing plays a part. If its in a box out of UV light and not being hit with branches and the ground, it will be fine.
Posted : 04/07/2020 12:54 pm
 LeeW
I think UV is potentially the biggest issue - same with unprotected (lacquered or painted) carbon fibre.
As long as it has been kept in a box and not in the shop window in direct sunlight it should be fine.
Posted : 04/07/2020 12:59 pm
Wish I'd kept a link to that test of aged/"damaged" helmets that all tested fine...
What if it's in the 2020 catalogue?
Posted : 04/07/2020 1:00 pm
Helmets degrade at different rates from different sources ( time, UV exposure, sweat, heat etc)
No legal reason not to sell them that I know of but if I was the OP it would be going back. Its probably not degraded much / significantly if its been stored properly but there is no way I would accept it.
Posted : 04/07/2020 1:06 pm
singletrackworld.com/forum/topic/can-a-shop-legally-sell-unused-helmets-that-were-manufactured-6-years-ago/#post-11280691
As said, it’s the UV that degrades the polystyrene that is the issue. Met recommended changing your helmet every 3 to 5 years when I used to sell them.
Posted : 04/07/2020 1:30 pm
Yes.
Posted : 04/07/2020 1:35 pm
