Sony hx20v on starting sounds like an angry wasp is stuck inside. It goes off as soon as you put the camera down on a flat surface,any idea? If you don't put it down it will continue. Doesn't happen 100% of the time either. Any ideas?
Zoom lens got some dirt stuck in it?
Some Sony RX-100s do this and it's a problem with the anti-shake system in the lens. There's a firmware patch to fix it. It could be the same problem, especially if it stops on a firm surface..??
I found this, use at own risk...
[url= http://esupport.sony.com/US/p/swu-download.pl?mdl=DSCHX20V&upd_id=7780&os_group_id=5 ]Sony Firmware patch[/url]
Beanum..You are a genius! Worked.
