I know how to save routes from Tracklogs as gpx to import into my satmap.
However is there a way to do the opposite? I recorded a ride last week and would like to import into Tracklogs so I can play with the route. When you convert track to trail it is saved as a .map file which Tracklogs doesn't see. Tried just changing file extension as a .tel and .gpx but this obviously doesn't work. Tracklogs will open a map under the name but shows no trail. Obviosly need to convert the .map source to .gpx or .tel.
Any ideas?
AndyS
Cheers Munkster - had a look but am baffled by the site. Thanks for replying though.
I've just edited the route on my Satmap 10 now, just would have ben very convenient on Tracklogs.
Cheers mate.
ja, gpsbabel is pretty baffling i'll give you that. but it has worked for me whenever i've needed it - just need to play about a bit!
