Calling clever peop...
[Closed] Calling clever people - charging from dynamo & testing output
6 Users
I have a shimano xt 1.5w dynamo on my do-it-all bike which has been grand for running lights over the winter.
I'm going away cycle touring in a couple of weeks and it would be nice if the output was sufficient to charge /keep topped up the garmin 810.
Trouble is with the 1.5w, I dont know if I will get suffienct charge at 16-24km/k sorta touring speeds. The person on the chat box at rose bikes seems to think so.
A simple way to test the output would be to test the amps of the ac output when cycling along, but cheap multimeters don't tend to have this functionality.
i would prefer not to spend £70 on something whihc doesnt't work.
From first principles, I know that 1.5w @ 6V ac should equate to 0.303A @ 5v dc, but unsure if this would charge the device, nor doo I know what speed the dynamo delivers this output.
Firstly has anyone used this hub to power a garmin, and secondly any suggestions how one could go about measuring the delivered output accross a speed range?
Posted : 06/07/2016 1:47 pm
Quick google suggests the 810 battery is 1000mah - that means it would take one hour to discharge at a constant rate of 1000ma. Before even bothering to get the calculator out, that would suggest that you could fully charge the flat battery over 3-6 hours. Looking at it another way, if you start the ride with a full battery it's very likely to be charging faster than it is discharging, id say you're good to go.
Posted : 06/07/2016 2:09 pm
https://www.cycle2charge.de/index.php/en/ produces a USB output of 5v/0.5a at 12kmh, so if the 1.5w dyno hub is half the power, presumably you'd need to be doing 24kmh (about 15mph) to produce 5v/0.5a?
I have no idea if what i'm saying is nonsense or not btw.
Posted : 06/07/2016 2:16 pm
I'd be concerned about unregulated voltage spikes etc bricking my Garmin.
Posted : 06/07/2016 2:21 pm
I'd assumed the OP was considering some kind of charging gadget like the cycle2charge or Busch Muller luxos etc..?
Posted : 06/07/2016 2:27 pm
Yes, you'll want a convertor- I borrowed a dynamo/cycle to charge setup from a friend for a few days. It was an sp pd 8 so I think a higher output but would charge a garmin with loads to spare.
Some garmins get a bit unhappy about power dropping in and out. I ended up charging a usb battery pack during the day then using that to charge garmin/phone at night.
Posted : 06/07/2016 2:36 pm
I'd use a cache battery inbetween the dynamo and garmin. All the stopping and starting will break it. Cache will give a constant supply.
Posted : 06/07/2016 2:46 pm
