cable runs on a 456...
[Closed] cable runs on a 456?
6 Users
 ton
can you run full length outers on a 456 frame.
anyone know please.
Posted : 04/01/2012 8:04 pm
Yep, built for the British slop.
Posted : 04/01/2012 8:12 pm
Couldn't run full length outer on mine unless i've completely missed something. The top tube has a full run for clipping the brake hose in, then the other mounts are for split outers unless you drill them out.
Posted : 04/01/2012 8:15 pm
 ton
cheers mate
I've had two of the 456's, one was the mk1 in "that blue" with the closed brake hose runs which was a pain in the ass as you had to take the calliper off and run the hose through. I then had one of the "new colour" ones in pink, both of these were only able to full length outers.
Posted : 04/01/2012 8:21 pm
But you could still go with Gore RideOn if your budget stretches. Worth it for me, although YMMV.
Arrghh, I had the original that blue 456 which indeed had full lenght cable outers.
I though Ton was referring to the C456 which I now own which does not have support full length cable outers.
Posted : 04/01/2012 8:28 pm
mine has full outers 🙂
Posted : 04/01/2012 8:31 pm
full outers on my chocolate brown steel jobby (second gen..?)
Posted : 04/01/2012 8:33 pm
I forgot about the plastic version.
Posted : 04/01/2012 8:35 pm
