Buying a middleburn...
[Closed] Buying a middleburn UNO crank do I get Isis or square taper ?
9 Users
After much thought n reading up on threads I have decided to go with a new middleburn UNO crankset for my SS build. I havnt used square taper for a long time as my last few cranks have been X- type. Is this a problem as far as reliability and weight when looking for a BB . Or is it better to go Isis version though I've heard a few problems with that type of bb. The rx-8 type UNO looks nice but is alot more ££ so its square taper or Isis ?
Anyone who could help put my mind at a ease before I purchase ?cheers
Posted : 31/01/2013 6:41 am
Never heard of x-type. Square taper is as reliable as it gets. I guess they weigh more but who cares about that.
Posted : 31/01/2013 6:55 am
X-Type = RaceFace's version of hollowtech II
Posted : 31/01/2013 7:19 am
I'd never use Isis again , very short bb life not as poor as pf30 though
Stick with the taper either shimano un 55 or if you have the money Phil wood or Royce
Posted : 31/01/2013 7:33 am
 JRTG
Get the x type. Worth the extra dosh. Isis is rubbish and st bb that are good quality are getting scarce. Be aware that the xtype uses a different chainring....
Posted : 31/01/2013 7:34 am
So for a single speed frame being my onone inbread would the middleburn rs8 x-type crank work as well as the rs7 or rs8 square taper .as far as alignment etc .its nearly £100 more for the xtype UNO over the taper so still not sure i can justify it .rs-7 with a coated UNO ring is £138 where as the rs8 UNO xtype Is £220
Posted : 31/01/2013 8:09 am
 mos
If you get either isis or sq taper, you won't be able to fit them on a BB92 type bottom bracket if you ever change your frame. However if you get the x-type you will be able to fit them to everything.
Posted : 31/01/2013 8:17 am
I had ISIS on my SS before and sometimes I had to change the BB after 4 weeks! I now have the Uno crank set with a square taper BB. It's had a few years use now without any problems. I just stick a Shimano number in there and it holds for a few years. If you can stretch to the external bearing version then fine it's lighter but if that's not an issue the square taper is just as good.
Posted : 31/01/2013 8:20 am
Cheers guys ,I'm only going to use the crank on this ss bike so not worried about fitting it to other frames but I guess I wAnted to try and keep the weight down so didnt know if the light weight square taper bb's are at a price that would bring the complete kit to about the same as a x type set up .
Posted : 31/01/2013 8:32 am
HAve a 123 mm sq taper Royce bb lying around somewhere if you wanted. I use the sq t on a couple of bikes and they work really well. The bb's are smoothera nd more long lived that current external HT.
Posted : 31/01/2013 8:42 am
Trapper and a Phil bb, should be cheaper than the x-type, and the Phil wood will last ages and they will still be making them for a long time.
Messaged u mate ref bb you have cheers
Posted : 31/01/2013 9:25 am
Oh yeh my bb is 68 mm will yours work?
Posted : 31/01/2013 9:26 am
