I know it is discussed here quite often, but we are in the process of designing a new garage which will be a normal sing,e garage with a lean to on the side for secure bike storage.
Are there any good examples out there?
Should we build it from wood or brick and mortare?
What are the pitfalls?
We have a basement spit is really just storage
I know permitted development here states it must be built from non combustible materials if within 1 (or is it 2) meters of your boundary.
Check out what you can build first and then go from there.
I don't think that will be an issue here (Denmark) as many buildings are timber and we are replacing an existing wooden garage with a new one plus a bit on the side
I thought there would be some takers for this, certainly some of you have been known to show off your outbuildings from time to time 😉
Hi,
Work out what size you require, then make it bigger! you can never have a shed thats too big...
Interested in this, would have thought there are prefab wall/roof panels around to use?
Look no further [url=
y's Ultimate Workshop[/url]
You can buy precut kits for various garages and sheds, but none that are exactly what we want. I also lik the idea of designing and building my own.
Tommys workshop looks good, I'll see if I can find it online.
Stoner???
here is mine...
... so far !!!!!!!
footings dug for a small retaining wall, back fill, then raft slab approx 7m x 4m, then employ bricky to construct single skin concrete block walls and i plan to do the rest. Wish me luck cos i've never built anything like this before!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Qwerty. I'll be interested to see and hear how that turns out
you n me both!!!!!!!!
💡 wrightyson has some brains to be picked
7m x 4m
That ain't no shed lad, you could house 3 students in that.
when i lived in that larnden and had a (shonky) garage built that was exactly the advice of our Turkish neighbour 😀
