BSP pipe fittings. ...
BSP pipe fittings. Very confused!
8 Users
4 Reactions
I am working on a diy project. It calls for a specific pump (SU fuel pump fwiw) with what’s sold as 1/4”Bsp female threads.
IMG_1320
Bought the pump and a 1/4”bsp male thread to 6mm ID hosetail. IMG_1319
clearly the two items, whilst sold as 1/4bsp are different sizes.
no problem, pop off to local toolstation who have a 1/2”to1/4” bsp converter. 1/2” way to large but confusingly the 1/4” is the same as the pump diameter.
Ok so the hose spigot I was originally sold was sent was wrong. As a check I asked if they had a 1/4bsp fitting I can check, and that was the size of the original spigot I brought in.
so I have two items claiming to have 1/4bsp female threads being the same size and similarly two items with 1/4bsp male threads being the same size, but smaller diameter than the matching female threads.
confused? I certainly am! what on earth is going on?
what do I need to buy to fit my pump?
Posted : 05/11/2024 7:34 pm
 Bear
Could be 3/8”
Posted : 05/11/2024 7:47 pm
3\8ths? About 15mm ID
Posted : 05/11/2024 7:51 pm
The brass hosetail looks like 1/4 BSPP (parralel) is the pump 1/4 BSP tapered?
Posted : 05/11/2024 7:52 pm
 Bear
Might be a NPT thread or some obscure American thread too!
Posted : 05/11/2024 8:09 pm
 lerk
The hose tail(s) are 1/8”bsp
1/4”bsp has a major diameter of 13mm ish like your pump.
https://images.app.goo.gl/NwoWecc3uCChTEjm6
whoever you’re buying your fittings from is thick!
Posted : 05/11/2024 8:13 pm
+1
BSP fittings are sized based on the ID pipe they were attached to.  So modern 15mm (OD) copper pipe has 1/2"  fittings, whereas 8mm has 1/4" fittings.
Posted : 05/11/2024 8:44 pm
Murray and Murray reacted
 pk13
Those fittings are the only thing I often have a spare bag of *ie I brought the wrong size/fit when I did the fuel system on my bus it was a lottery of non fitting fittings. I got so fed up at one point the lathe got fired up in my mates shed
Posted : 05/11/2024 10:39 pm
zntrx and zntrx reacted
I'm guessing that's something more interesting than the STW standard issue T6 California @PK13?
Posted : 06/11/2024 8:21 am
 pk13
Well it's a vw. It did have full on fuel injecton but I've gone back to carbs less stress less fittings.
Sometimes simple is best.
Posted : 06/11/2024 8:24 am
 Sui
pk13
Well it’s a vw. It did have full on fuel injecton but I’ve gone back to carbs less stress less fittings.
You not thought about about getting SU injector conversions / throttle bodies?  Jenvey do some nice ones as do https://www.classicfuelinjection.co.uk/vw-beetle-single-36mm-kit - i tried some out in smoe older jags - they make a huge difference and way more efficient.
If you already had injection you must still have the looms in place?
Posted : 06/11/2024 9:45 am
 pk13
@sui everything is back in a big box in my garage thankfully vw engine wiring is all at one end so it was just unplugging the pin plug. When I get time I will revisit it definitely unless electric becomes viable in a full camper.
I took the engine out to finish some panel work and just laziness made me put the carbs ect on I can be stubborn for all the wrong reasons lol.
Posted : 06/11/2024 11:12 am
