hi, my hope pro 2 hub ive just fished out of the garage is in a bit of a mess and i looking for a bit of advice... i know it needs new bearings and the free hub works but there is a bit of play in it!
after a basic bearing change will the play in the free hub stop? or is that a different job altogether? and if so what needs doing to make it good again?
thanks alot:)
Alex
As long as no parts are damaged like the axle, the play will probably be from the bearings. A bearing change should sort it. Hope have a great video on how to do it on there web site.
excellent guys thanks for your help:), ill strip it down and have a look at what im dealing with, but if its a bent axle like you say i think ill just put it back in the garage! 🙂
